Guess who's back!?! Atl-atl's K5 Blazer + Four Wheel Camper "The Crawlin Cabin" documentation thread!
arveetek
Lastly I want to figure out how to wire the stock Blazer tail/brake lights so I can plug them into the 4 pin of the RV so I can ditch the magnetic trailer lights.
I recommend these diodes from Roadmaster:
Essentially, you cut the factory wiring going to the taillight, then splice one diode in on each side. You will have two inputs and one output: one input is the factory wiring and the other input is from the 4-way from the motorhome. The output goes to the taillight. Makes it a cinch and keeps everything working properly so there's no backfeeding through the turn signal switch. Simply run a dedicated, permanent flat 4 wire from the front of the Blazer to the rear, and then use a short quick-disconnect cable between the front of the Blazer and the rear of the motorhome.
You don't need a diode on the clearance/running circuit, as it can power up all the clearance/running lights on the Blazer with no problem.
Casey
Kingsize24
Once I got it back from powder I mounted the winch and started to test fit the bumper.
The winch didn't clear the "wings" of the Engineered Vintage frame plates so I had to cut them down. Thankfully I was able to cut them flush to the frame rails without getting rid of any mounting holes I was planning to use.
Here they are trimmed, painted and mounted back up.
I picked up a cheap 12,000lb Badlands winch from Harbor Freight that has a removable control box so I mounted that to the frame and wired it all up. The winch hangs upside down but its 2 1/2" higher up than the Engineered Vintage mount so the "bottom" of the winch sits higher than the bottom of the frame rails which was the goal all along. In the future Ill build a bolt-on skid plate for under the winch that has a cutout for the free spool lever.
And the final result. I love it so much!
I love it as well. That's a damn nice looking bumper build you did there!
arveetek
Anyway, my mom found a picture of me and my dad with the truck that started my love for squarebodies. This is some time around 1990. Dad bought the truck new and it was his favorite thing ever. It was done up all custom by a conversion company whos name I cant recall, it wasnt Geneva. It had engraved woodwork all throughout the inside depicting scenes of ducks on a pond. It was so incredible.
Sweet rig! I absolutely love the old square bodies with conversions. I would like to have a crew cab C/K30 Western Hauler edition myself.
Casey
Atl-atl
Im planning to bring the Blazer to the Vintage Offroad cars n coffee at FourtillFour in Scottsdale tomorrow morning if anyone happens to be around, come say hi!!
Atl-atl
Well I have some unfortunate news. Nothing bad happened to the truck but my account here on Expedition Portal was hacked. Back in March someone took over my account, deleted my entire history on Expo Portal and listed scam ads in the classifieds. Ive been working with the tech team here to try resurrecting some of my accounts history, with some success. This thread seems to be mostly intact. Some of my other build threads are missing pictures or posts or entire pages. Im really saddened by this but things seem back to normal now. Ive started trying to contact the people that were trying to buy stuff from the fake ads so I can apologize but its taking a while to get through the list and you can only start a private conversation on this forum every 5 minutes or something like that.
Anyway, Im really glad to be back and PSA, change your password.
Mike
V45W_Proto2.5
