Actual off road capability of composite campers.
Reno_Nate
Question for the group. For those that have built a hard sided composite camper what has been your experience with its capabilities off road? Seem like they have a real high center of gravity. Currently have an F150 with a small slide in. With a 2in level and 33s it goes most places I want it to. It's a little small for our growing family and looking to upgrade. Originally was thinking van but they don't seem super capable and have a high COG. So thinking trade in the f150 for a 350 and do a flatbed camper . I'd love a popup OEV but they are out of our price range and FWC seems like they have a lot of condensation issues in cold weather. So wondering about a composite hard side but will I have the same issues as a van with high COG? we are mostly weekend warriors to a week out. Thanks!
Sent from my SM-G781V using Tapatalk
rruff
It won't be very different if you custom build to similar specs. To reduce COG concerns, keep the heavy stuff low in a custom build.
You seem overly worried about COG, but you'd need to be on >40 degree angle for that to happen, or make a silly maneuver, or have the road collapse. Ground clearance and roof height are more common limitations for getting places in a big rig. Traction and turning radius are important also.
andy_b
To anser the question: we haven’t had issues. As long as it fits (and we don’t always and still make it) we are fine.
If you keep the big things low, minimal stuff on the roof, and exercise restraint when installing and loading high cabinets, you should be fine. We left out upper cabinets in our build for this reason. Our COG is just behind the rear wall of the truck cabin at the level of the framerails.
Off camber feels dangerous but rarely is.
geoffff
Hard sided campers typically have a CofG advantage over slide-ins (we have had both) because the water tanks are below the floor instead of above it.
This rig weighs about 6 to 6.5T.
Wow, that's impressive!! :0
I was curious, so I measured the worst frame of your video. Looking at the trees, the camera seems to be tilted about 4°. After compensating for that, I measure 23°. I'm surprised how scary 23° looks!
rruff
We usually pucker up and freak out when we get about half way to the tipping point. Because he's bouncing, he's probably over half way.
To clarify, in a static situation the CG needs to tilt past the tire contact point that you'll be pivoting on when you tip over. For instance, say his CG is in the center of his rig, and at the level of the top of the radiator where you drew the line. If you draw a vertical line through the tire contact with the ground, he's still a long way from that point. And his actual CG is probably quite a bit lower.
  • Like
Reactions: mog
V45W_Proto2.5
