Older Rig with upgrades vs Newer Truck near stock?
85_Ranger4x4
Inquiring minds want to know. Unless he means extended warranty...or he had it totalled by some acquaintances at the bar
It is less than ideal and may vary by state or whatever but you can run major auto repairs thru your vehicle insurance same as a collision.
However I am sure they love to jack with your rates and/or kick you to the curb for doing so.
ThundahBeagle
Always thought that's a good idea, however, I've not encountered that here in Taxachusetts...I shall inquire but I think I know the answer.
montechie
This is one of my biggest questions... what do people mean when they say suspension is 'better
1. Better ability to go fast and maintain control, avoid bottoming, not be overwhelmed. (probably means worse 'comfort' at moderate speeds). I'm not an expert but i assume this is acheived with longer travel and heavier damping.
2. Better articulation/travel for severe trails / crawling
3. Better comfort when traveling at 'normal' moderate speeds on bumpy roads / light trails. Less jarring, softened jolts. This might mean the vehicle is worse at going fast. I'd imagine the best suspension could do better on all 3 counts than stock, but i don't know if that will be in my budget.
Across my Jeeps, Toyotas and Fords I've never had a suspension kit that made my highway or off-road driving worse or less reliable from OEM. I live in the Rockies in a rural state with high speed limits and a small budget for road repairs so cornering, pothole handling and corrugation compliance is is weekly and rather important to me.
Strong mid-level shocks with the valving style you prefer can hit that goldilocks zone of great off-road characteristics with better on-pavement or high speed performance. Bigger shafts, better heat dissipation through aluminum bodies and increased oil, bigger stroke lengthes, and superior valving will all outdo most stock shocks. Doing your homework on digressive vs linear vs progressive shock valving can make a difference. I really liked digressive valving on my IFS rigs (mid-tier Bilstein and Icons), but prefer linear on my Jeeps.
For #2 if you land up with an IFS rig, I'd get longer control arms as part of a kit, they increase droop. Arms will also widen that goldilocks zone for handling if you lift the truck, they help maintain stock like suspension travel paths. Get coils and leafs that match the load carrying you'll be doing. They'll allow your shocks to extend better on rough routes or high speed bumps.
Henrybrowne
