Box-Truck a bad idea ?
amad
Hey guys,
Planning to buy a box-truck Hino 300 or Toyota Dyna since a composite panel one is way outside my budget.
Is there a risk of condensation with box-truck body ? Can't find a lot of resources on how people deal with it !
I'm afraid of waking one morning and realizing all my the frame is rusting & wool is rotting :/
Was thinking XPS foam in the frame rib + 20mm foam on top of it and 8-10mm plywood with the minimum screw possible attaching it to the frame, since I think all the cabinetry will add a ton of strength between all the sides once finished.
Thanks !
simple
What materials are used to make the box portion of the truck in NZ?
Could you find a box truck with an aluminum framed box and use foam board?
Some box's in the US are also made with uninsulated composite panels.
amad
Most I've seen are stainless steel frame with corrugated steel sheet :
I think I would need to spray foam + foam board it, but the frame would make a lot of thermal bridging If I only insulate between the ribs :/
Henrybrowne
