6th Gen vs 5th Gen 4Runner: My Perspective: 10,000 Mile Update
Mack M
For anyone that finds this useful, this is my take on the two, after owning 3 previous 5th gens and now a 6th gen (for the last month with 2,000 miles on it including towing miles). Additionally, I have owned 1st and 2nd gen Tundras, a 200 series, a GX 470 and 460, a 1st and 2nd gen 4Runner... I like Toyotas.
5th Gen:
The 5th Gen 4Runner is an absolute beast of a vehicle. The 1GR-FE is as bulletproof as Toyota engines get. Likewise the 20 year old A750 5 speed almost never failed. The word 'bulletproof' is the embodiment of the 5th gen 4Runner. As a former owner of the platform, there were only two downsides to me (a 40 year old, 'overlander' that cares more and more about safety after being in a serious auto accident last year and not about power and going fast):
1. The 5th gen was very picky about tire balancing and weight. All three 5th gens I owned, and thousands on all the forums, had issues when bigger tires were mounted, and suffered from wheel shake. This included 2 brand new units I had with less than 10 miles on them when switching to bigger all terrains (even modest 265/70/R17). This has been completely fixed on the 6th gen.
2. Crash safety: older vehicles simply don't perform as well and the 5th gen (same with the GX 460) left a lot to be desired in moderate offset and front end collisions, leaving the driver footwell very compromised: https://www.iihs.org/ratings/vehicle/toyota/4runner-4-door-suv/2022. The 6th gen, given that it is structurally similar if not identical to the 2024 tacoma all the way to the cab, has improved crash testing significantly. You can have a lot of problems in life, until you have a health problem, then you only have one problem. Safety is crucial, and I'm glad to see Toyota engineers improved the platform in crash safety.
That's it, I can find no other complaints on the 5th gen, I loved all of mine, and probably would still own one if it weren't for the vibrations that I was getting through the steering wheel every time I tried to mount larger all-terrain tires.
6th Gen:
The 6th Gen is a stark departure from the 5th gen. It is very close, if not identical to the Tacoma in every mechanical way (the 4Runner is thankfully still made in the Tahara factory in Japan, likely the best automotive plant on the planet). It features a 4cylinder turbo with hybrid option. It is no longer only port injected, but now includes D4S, Toyota's port and direct injection system, that in other models, works very well and is very proven.
As someone that very much liked the 5th gen drivetrain and did not think it was underpowered (despite living at 5,300 feet above sea level) for a midsize SUV, I can tell you that the 6th gen drivetrain (in terms of drivability, not necessarily durability and longevity) is a vast improvement. And again, I love the 4.0 V6. The 2.4 Turbo (mine is gas, SR5) and 8 speed are fantastic. There is occasionally a small hesitation/rough shift between gears 2 and 3, but it's not that annoying and only occurs to me under spirited acceleration.
On a recent drive from Boulder Colorado to Lander Wyoming (a route I drive regularly for work), and a route that previously in my 5th gen, was always filled with downshifting and 4,000 RPM, now is quiet and effortless. The 6th gen almost never even downshifts, and when it does, I stay at speed well under 3,000 RPM. The real world torque is very noticeable, and such a pleasant experience and the 8 speed gearbox is a welcomed addition. I also greatly appreciate the 6 grease zerks found on the front and rear drive shaft. I can't recall if these were present on my 5th gen, but either way, serviceability is a win in my book.
As soon as I got it, I added my favorite tire, the Falken Wildpeak AT4W, in a modest 265/70/R17 in SL variety (this is my commuter so no need for a C rated or E rated tire). Prior to doing this, the 4Runner was achieving (again at altitude, where I always experience better fuel economy than at lower altitudes) 26.1 mpg hand calculated (although the computer is almost identical and is very accurate in my experience). After the tire upgrade, I've been averaging around 22 mpg, so a significant hit, but still a very good number for a 4,600 pound SUV with all terrains. The air dam will come off soon:
Towing with the new 4Runner is equally is enjoyable. The power and low speed thrust is considerable. I towed my 7x14 cargo trailer with a couch and some other furniture about 50 miles (trailer probably weighed close to 4,000 lbs) and it pulled very well; much, much better than my 5th gen.
I appreciate the SR5 coming with 17 inch wheels and wish higher trims would do the same. 18s, 19s and 20s, do not belong on an SUV intended for offroad use in my opinion.
The user experience of the 6th gen has been delightful and I'm happy I made the switch. Many people complain about materials, but the plastic dashboard and armrests by the window do not bother me, and again, as a rugged all terrain machine, I prefer more durable materials that can take more of a beating.
The only annoyance so far on the 6th gen is that the plastic body moulding on the rear tires fills with mud, and even after a thorough car wash, it was still there. I had to clean it by hand while opening the door. But again, this is a very small thing.
Style is subjective, and I do prefer the 5th gen more than the 6th, but things have to evolve I guess.
If you have any questions about the comparison, let me know. I think Toyota did well. Yes it has a 4 cylinder, and a turbo, but servicing this engine will be very easy (spark plugs should take less than 10 minutes, which is great, given that they are called for every 40,000 miles in the 6th gen), and the driving experience is far better than the outgoing model.
4RunnerGuy
Nice 6th gen and I especially appreciate the color, as white is my preference of color for all of my vehicles if given the choice.
I've been driving Toyota since my first, a bought-new 1984 4WD pick-up. Owned 1st, 2nd, and 4th gen 4Runners (still own two 4th gens).
I anticipate than in a couple of yrs I'll move on from my 2004 (in my avatar) to a new 6th gen or 250. I seem to remember every time a new gen 4Runner would come out, some people would complain that it's a downgrade from the previous gen, but soon afterwards that would be proven false. IMO the 5th gen will reign as the perennial favorite simply due to its long production run. If only the 2UZFE was an option in the 5th gen! That said, I'm not sure why some people cringe at the thought of a turbo 4 cyl made by Toyota. Toyota had a turbo 22RE in some of their trucks close to 40 yrs ago. I drove one from Laguna Seca back to Los Angeles loaded up with two girls and their camping equipment back in '88 and it was amazing compared to my 22R. And Toyota's been doing hybrids over a quarter-century now, as the first Prius came out in 1997. As for the grease zerks, with my 4th gens, the 4WD has them, the 2WD does not as it's a "sealed" driveshaft.
sn_85
I won't have as in-depth of an opinion here but after owning 2 5th gens and sitting in the recent 6th gen I could not see myself in a 6th gen. I don't mind the plastic interior, the 5th gen uses plenty of plastic but it's the quality of material that's extremely questionable in the 6G. The plastic is thin and flimsy. If I touch it it bends. It honestly feels like the interior of a Ford Bronco. The 5th gen used a lot of hard plastics that don't creak, bend or vibrate. Everything feels substantially cheaper in the 6G except of course the price tag which is about $10-15K more than previous.
Personally I'd rather get a low mileage 5th gen, regear it to 4.56 and throw a Magnusson S/C in there. All the reliability and power without sacrificing on quality. Even after those mods you'd still be under the cost of a 6G.
Mack M
A few more thoughts after 10,000 miles:
I still very much like it. The driving experience is superb, compared to the 5th gen, which I also really liked, with the exception of the soft suspension. Though I will say, the 6th gen's ride can be a bit rough, but it's a utilitarian SUV.
People complain about the build 'quality' but I find the build quality to be the same as the 5th gen, and do not conflate material choice with 'build quality.' As an (despite it not being cheap) 'entry' level SUV, at least in SR5 form, I appreciate hard plastic on the door sills, that can get rain, but, pet scratches, etc, and be ok. I don't need soft touch materials throughout my rugged SUV intended for tough use. If I was buying a GX and it came with this much plastic, I would be disappointed, but not a 4Runner, I find the material choice appropriate.
The powertrain continues to impress, I appreciate a longitudinally mounted inline engine, both for a reduction in complexity, and for ease of maintenance. I can change plugs in 10 minutes, and if I find myself in remote Bolivian with basic hand tools (which I plan to take this vehicle), I feel confident, that if I could get the part in via shipping, I could change the turbo on the side of the road in a half day, not something I could say for example, about the V35a, with it's V configuration and turbos tucked way up against the block. Is the inline 4 as refined as a V6? Of course not, but I'll take simplicity and slightly less refinement over more complexity and more refinement every time, particularly in a body on frame SUV; again if this was a luxury car, I would think otherwise.
Fuel economy has a lifetime average of 24.6 mpg, running premium every tank, at altitude. I drive easy and try. When down at sea level, I see around a 2-3 mpg decrease, with the denser air (something I've always experienced in all vehicles I've owned).
Room for improvement. I'm very content and anticipate keeping the vehicle for the long term, but nothing is perfect and these could be improved:
  • The phone holder gets very hot when running heat (I feel if I leave it there I'm cooking the battery).
  • The way the rear wheel well is constructed allows mud and dirt to get up under the plastic trim, which only becomes apparent after a car wash when opening the rear doors. I feel this could be improved with a redesign on the plastic trim pieces.
  • The infotainment system sometimes does not display the music that is playing, this is a slight annoyance that isn't a big deal at all, but something that could be improved.
  • I do not find the seats particularly comfortable, actually, out of all the Toyota models I've had (most), these are the least comfortable seats I've experienced and the only thing I actually consider changing. This is subjective obviously.
Overall a great vehicle and in a world where many problems are prevalent (Tundra main bearings, GM transmission valve bodies, Ford transmission issues and cam phasers...) it's good (knock on wood) to have a seemingly reliable, well build SUV.
Gravelette
Thanks for the update! Did your 4Runner come with a hitch, 7 pin wiring and a Tow Mode? Were the mirrors adequate when towing your trailer? Also, what is the door sticker payload? I'd really like to have one of these for "made in Japan" build quality but I'm concerned about whether it would be a reasonable choice for pulling my small 3000# travel trailer.
Mack M
My sticker says the GVWR is 6,075 lbs, and according to the website, my curb weight is 4,685 lbs, so a payload of 1,390 lbs. I believe they all come with a 7 pin, 4 pin and tow mode. I just got back from a 1,000 or so mile trip where I pulled my trailer from front range Colorado to Jackson WY to pick up a side by side. This configuration weighed almost right at 3,000 lbs. Pulled very well, no weight distribution hitch, just plain tow setup. If I was going to tow that weight regularly, I'd want a trailer brake controller. I think it would be good for towing a travel trailer of that size. The mirrors were adequate for the side by side, but not for the cargo trailer, for that I would want mirror extensions.
Mack M
Sorry just saw this, (I know this is super old haha), but I know the higher trims increased significantly in cost, but my '25 6th gen SR5 was $43k, my '23 was $41k. More, but fairly reasonable. The upper trims did increase quite a bit, which is unfortunate.
deserteagle56
Never EVER go by the manufacturer's listed curb weight! Run the rig over a set of certified scales if you want to see what it really weighs.
I own and have owned multiple vehicles and I've always found the listed curb weight to be way low. Not sure how they get that listed curb weight but it must be dry with no fluids (including gasoline) in the vehicle.....and perhaps helium in the tires!
Here is a photo of the weight of my 2022 TRD Off-Road 4Runner, on a State of Oregon certified scale. That's with about a half tank of gas and nothing else inside the vehicle.
Mack M
Thanks, that is good to know!
PNWav
