On-Board fresh water system
articulate
Desertdude said:
Mark - Glad you are working on the number two need for expedition travel- ( first one being fuel for the vehicle... gotta keep moving right? )
here is where I bought my junk Since this was a test I did not want to spend the farm on it - in case it leaked/fell apart/or tasted bad - Baja wash-board road tested months later all is good
One other idea is to make a complete system in a removable platform/crate - lock it down in the truck bed easy on easy off - with the right size it could be loaded onto any vehicle...
I went with the 21 gal poly tank - 2.8 gpm shurflo - (overkill for sure on the gpm but it was cheap)
I am setting up something similar in the 80 series landcruiser where the second row seats were :)
Excellent! I understand your concerns about the taste, but the other day I realized we drink water from plastic bottles all the time. Moot point now since you've installed, tested, and used your set up already.
YES! I've seen that shurflo, and that seems to be a good ticket.
Jonathan Hanson said:
One thing makes me nervous about that very nice underbody poly tank, and that is the offchance of it getting holed and losing all your main water supply on the trail without realizing it. On the other hand the center of gravity issue obviously favors chassis mounting.
100% agreed. That's why I figured a nice steel plate would be sufficient to protect the tank. With having to remove my exhaust pipe and the drive shaft to put the tank where I thought it would fit best, I'm now saying screw that. Know what I mean?
I'm just going to do a truck bed tool box and put the tank in there. The box is useful anyway. I see this solution as a win-win. :)
Pasquale: Where is your tank drain line? Did you poke a hole in the bed of your truck? And do you have an accumulator as well or just the tank->line->pump->line->spigot set up?
mcvick: You serious about tank fabbing? It might not be necessary, nor worth it (to purchase all the equipment to do it). 10-20 gallon tanks are running between $50 and $100 with the fittings installed; tanks might be cleaned in some "special" way to make them IAPMO approved and taste-free. Unless you're interested in poly welding as a hobby :).
Cheers,
Mark
Brian McVickers
Administrator
Staff member
Purely interested as hobby. If it's not that difficult and does not require any serious equipment then you could probably make something that fits your vehicle just the way you want. Just an idea though since I know nothing of poly welding. I just like to make stuff!!!
Desertdude
I have a line with a garden valve that has about 24" of line on it - I keep it coiled up next to the tank and use it as a vent line when filling and a drain if I need - I used a west marine filler on the side of the truck ( I love drilling holes in the truck body;)
yes - just the tank->line->pump->line->spigot set up
the spigot I got from Home Depot -its a bar sink faucet :)
saburai
Back from the dead!
You wouldn't happen to have pictures of your set up that you would share, would you?
Many Thanks...
Mickldo
These are Aussie sites, but they may give you some ideas:
Opposite Lock
Long Range Plastic Water Tanks
I mounted the vertical mount slimline Opposite Lock 40L tank in my 80 between the cargo barrier and the sliding drawers. To fill it I slide open the side window and stick a garden hose in the top. When I don't have access to a garden hose I have a short length of plastic hose and a funnel for filling with a bucket or jerry can. There is an outlet to which I have attached about a metre of clear plastic hose. This has a small inline plastic tap on the end. During normal travel this lies along the sill of the rear door opening. There is enough length that it can be brought out away from the car (and the mud) and let gravity do its thing.
I originally had plans of hooking it up to the under bonnet heat exchanger and pressure pump and maybe work out some sort of filtration system but it works beautifully how it is and is so simple. The pressure pump I have is a 17Lpm pump and the tank is only 40L so it would empty the tank in just over 2mins. So the shower is kept for times when I have access to plenty of water (creek, etc) and the water tank is for drinking water only.
LXRACR
H20 tank...
Would it be easier to fab a spare tire carrier and utilize the factory spare location to mount a tank and skid plate? Thats what I did, no loss in ground clearance and I was able to fit a 17 gallon tank. Just an idea that I'am sure has already been suggested.
articulate
Wow! What an old thread! Since starting this thing nearly three years ago, I did exactly what you suggest.
Page with details.
Squall Line
This question may be rather uniformed, but I have always wondered: do you have to take a lot of care to ensure the tank remains 'safe' for drinking? During periods of it being empty for instance, is mold a great concern? How about concerns with the water source, and even the supply hose used to fill the tank? I am a ways off from even considering a move (though I really like the idea), but have thought about it none the less.
Eric
LXRACR
No worries..
It hasn't been a problem for me, what I do is keep it filled with a bleach concentration in the water. I filter the water going in and going out. When I get ready to use, I simply drain, flush several times, and re-fill with filtered potable water. Never an issue. If you live in feezing climates might have to use a different approach though... The way I look at is, if there is ever a SHTF situation, I have 17 gallons of h2o ready to go (on top of other supply) for cleaning, etc. (not for drinking all year round because of a small amount of bleach).
articulate
To help prevent algae growth, it's important to keep the opaque tank out of direct sunlight as well. But, yes, you do need to take precautions to keep the water safe.
V45W_Proto2.5
