BlackX - 2007 Xterra Off Road
BlackX
Hello. Thought I'd introduce myself here.
Year: 2007
Make: Nissan
Model: Xterra
Trim: Off Road Auto
Color: Super Black
Mods:
BFG All-Terrain 285/75/r16's
Stealthed wheels
Shrockworks sliders
Shrockworks skids
Shrockworks rear bumper
Rancho Quicklift
Calmini shackles
2' Firestik
Cobra CB
Yaesu FT/7900
400W Inverter
KC long range driving lights
K&N drop in filter
Campinglab Roof Top Tent
Custom BajaRack
Total Chaos Upper Control Arms
BlackX
Nice looking rig! How did you mount those lights on the front? Any shake?
Thanks! Originally I was going to mount the lights in the lower air dam which I have seen people do. It would have involved making a mount. Before I did that I decided to see where else I could mount the lights. I ended up putting them in the current location because there's a metal support behind the bumper there and all I had to do was drill in and mount. There is very little shake. From what I've seen there's less shake than others who mount them on light bars. It might be because the plastic part of the bumper helps sinch it. I don't know.
I'm hoping it's only temporary until I get an after market bumper. But that's what I said a year ago.
Rev
cool! So did you have to take the bumper off, or did you just measure it out and drill through the bumper and metal behind from the top? It is hard to tell exactly where they are mounted from the pic.
I hear ya about the bumper, it is expensive. Part of me wants to be different and keep the stock bumper though. I sort of like it anyway.
Anyway, your looks really good and the lights are well done. What kind of lights did you get (fog, driving etc...)?
BlackX
Here's a close up if it helps. No I didn't need to remove the bumper. Just measured very carefully since there was no turning back once the first hole was drilled :) I use the KC Slim Lights Long Range Driving lights. The light is too concentrated though. My plan is to eventually change the 2 outside lights for a wide beam of some sorts or just add some sort of shim to point them outward a little.
Rev
thanks!
Where did you run the wires through?
sorry for all the questions.
BlackX
No problem with the questions. I drilled a hole for the wires just above the hole I drilled for the mounting point. Ran the wires along the passenger side fender in the engine bay, across the firewall to the drivers side, poked a hole through the rubber boot in the wall with a wire hanger and pulled them through. I put the switches in the two blanks on the left of the steering wheel.
07OffRoadXterra
Welcome! you have the same truck as me! Except, yours looks a whole lot cooler than mine! I'm hoping to add some lights but haven't decided on which ones yet.
BlackX
Just installed a new differential cover from Blue Torch Fab. The cover is very solid :smiley_drive:
and a Yaesu FT-7900.
Lockwoodjd
