Offroad Trailer Axle input
Martyn
Not to change topic, but where can I find the hub/brake setup with a 100 series landcruiser bolt pattern? It's 5x150mm.
Thanks
The only way to get 5 on 150mm is through using an adapter. North American common bolt patterns on 3500 lb axles are 5 on 4.5 5 on 5 5 on 5.5 and 6 on 5.5
jgolden
If I plan to run an adapter, which lug pattern should I go with???
Also, Does Adventure Trailer sell their Air shock to the home brew guys????
thanks
Martyn
thanks
Yes, but they are a very expensive items, the best, but expensive.
If you are looking for something budget we can sell the separate airbag and shock set up.
For a 5 lug adapter you need a 5 lug hub. I'd go 5 on 4.5 to 5 on 150
