Behold...my home-made Engel fridge slide!
Fergie
So....this project took me way too long...about three months or so, but in a short six hours this last friday, I've reached the denouement.
Some folks here have built their slides using drawer slides, but after an ill-fated month of using drawer slides on my drawer system, and a subsequent catastrophic failure of said slide, I decided that if I wanted a nice HD slide, I'd need something more solid, and while I thoroughly enjoy both EE and SE, I wasnt about to give them ~$250 for a fridge slide.
So I did what any good shadetree does...I copied.
My material list is pretty straight forward:
3/4" plywood base(to be anchored to the WJ cargo area at a later date)
16 pack of ABEC 5 bearings from Big 5
3" L-angle from work
3/4" L-angle from work
Hitch pins
Nuts, Bolts and washers
1/2" L-angle from work
Rubber stops.
And, as I am somewhat lazy right now, and don't feel like doing a step by step write-up, and as design and engineering is part of the fun for me, I will leave you with pictures.
Hope this help some other folks with their ideas, and feel free to give feedback!
Gavin
I need to add some slide stops to stop any type of overextension, but through blind luck, and sloppy layout, the slide wedges itself stopped at full extension. I'll add the other stops for safety sake, and will anchor the entire assembly to the rear cargo area at another time.
The fridge feet are a tight fit between the crossbars. I will be adding a small piece of plate, and will get some longer screws, and will attach the feet to the plate.
It sits about 90% complete right now, but is functional and that is what I need.
Martyn
How will you gt to the spare tire below the fridge once the slide is fully mounted?
Fergie
Spare will go onto the roof as a temporary solution, but the final placement of the tire will be on a home-made rear bumper and tire carrier.
FourByLand
Looks great!
I would probably trim some the excess off of the slide so no one rips their leg open.
Glad to see some progress!
:arabia:
lqhikers
Made in America!
Perfect day to show a bullet proof product that is not imported!
As some one who also makes 99%of my expo products in my garage,this is one of the best!
Great job,great design,and if and when i need a slide for my Engle you can rest assured i will copy you!
Drive slow and enjoy "its the journey"
Les Lqhikers
adventureduo
Dave Druck [KI6LBB]
Looks perfect man! Yeah i agree, get some rubber covers for the end before someone does rip their leg open. I can already see me doing that easily.
Fergie
Well stay out of my fridge and it wont be an issue!
I hit the corners with a pearl and smooth the sharp edges out.
Thanks for the kind words all.
Now, I need to figure out a frame system for the tire well to support the fridge mount, and simultaneously build a rear bumper and tire carrier...so much to do!
Fergie
Went to HD today and finally bought some "Lashing Straps" to hold down the fridge to the slide. $8 for (2) 1" wide x 8' long straps.
I have my rough idea for a false floor in my head, so that will be my next project for the rear of the WJ.
Enjoy, yet again!
G
CanuckMariner/Nomad
Love having fun 😊 in the 🌞 by the ⛵ and the ⏳
Very nice design. Wondering how you got the 1/4" tubes attached to the angle iron? I suspect you welded them? I agree with the other posting might want to trim some material so you don't get bruises.cuts on legs etc. Looks good enough to copy....again! It's funny how each time something is copied a slightly different approach is used and simplification and BETTER! Great job!
Fergie
CanuckMariner said:
Very nice design. Wondering how you got the 1/4" tubes attached to the angle iron? I suspect you welded them? I agree with the other posting might want to trim some material so you don't get bruises on legs etc. Looks good enough to copy....again! It funny how each time something is copied a slightly different approach is used and simplification. Great job!
Thank you.
The 1/2" angle is welded to the 3/4" angle.
I havent noticed the angle protrusions to be an issue, but then again, I'm used to it. I think I might take a straight edge to the set-up to see how far they actually stick out.
Henrybrowne
