off-roader
I was tired of using 2 gps' for both topographic maps and street maps. Also the tiny screen is all but useless if you need to glance at the gps to find your bearings while driving off road. I knew I needed a better gps solution.
Of course there are also the more expensive gps systems w/ large +7"screens but don't have both topo and street navigation in one unit for a reasonable price. After searching for months I decided this isn't an offering any of the gps manufacturers are addressing currently nor would they be addressing in the near future as 99% of their clients haven't been asking for it.
I decided my best bet was to use a ultra light, ultra mobile laptop with a gps & topo/street mapping software.
Like the gps makers, I couldn't find gps mapping software providing both high res topo data along with street navigation data. I ended up using 2 software packages. National Geographic's Topo for California (which I already owned anyway) and Microsoft's Streets & Trips (also because it included a USB GPS receiver.
For hardware, I had been looking low and high for a suitable system.
Must Haves...
SSD (solid state drive) instead of a hard disk drive. I've heard all the nightmares with using a hard drive in rough off road terrain (it kills them quick) so an SSD was a manditory requirement.
8-10" LCD screen that was viewable in the vehicle.
Light weight: Less than 5 lbs if possible
Windows OS: As much as some people dislike it, it's still the most widely supported OS ON THE PLANET. Linux? Too much effort PERIOD.
I reviewed several netbook PC's including the ASUS eeepc and the Acer One. Both offer SSD's, Window OS, in a small light package. I also reviewed other lesser known manufacturers but I felt uncomfortable with their reliability.
I chose the Acer One primarily because of cost and availability. At $300 it was nearly $200 cheaper when I purchased mine!:Wow1:
I then installed both the National Geographic Topo Software and the MS Streets & Trips software on the laptop's 1st SD card (8GB) and it fit perfectly with a few megs of memory left over to spare. Since this laptop doesn't come with a CD drive I mapped my other laptop's cd drive via my home network in order to install it.
Next I needed to find a place to mount them on my 4x4's.
I own both a 1989 Mitsubishi Montero and a 1996 Montero. As part of their design both employ a center mounted gauge pod above the dash area between both passengers. This pod is of course mounted there with screws and I was able to fabricate a mount to fit both locations.
You can see the finished mount for my 96 in here... http://www.expeditionportal.com/forum/album.php?albumid=97
I'll post pics from my gen I shortly as well.
HTH some of you who may be thinking about where to mount a computer in your rig. Sometimes a bit of good old creativity is a better answer than a high $$$ alternative like the commercially available mounts from companies like RAM, etc.
:smiley_drive:
Must Haves...
:smiley_drive:
