Quick release mudflaps for all four wheels.
SixLug
I just thought Id post up my progress of making quick release mud flaps for my Jeep Cherokee in the General Mods section for those who might want to try something similar for any other vehicle. Its nice to be able to keep stuff off the side of the vehicle and out of the inside (when windows are down in on a wet road for instance), or off your dogs face when hanging out the window. Then when needed, for more intense off road driving, being able to take them off fairly quickly. I used stuff I had laying around, and the mud flaps themselves are a pair of 24" x 18" tractor trailer flaps that I will cut in half, giving me four. I got them for $30 shipped from an online truck supply. This is from my Jeep write-up:
March 22, 2009
Ok, got some work done on the rear brackets for the mudflaps. Pics:
Bottom piece with 2 holes in it is one of the arms that will hold the flap. These two holes will mount to an L-bracket with detent pins, eventually. For right now, since I dont want to drop $25 on pins, Im going to more permanently mount them with some nuts and bolts. Still removable, just with a 7/16" wrench.
The arms are 1/2" C-channel aluminum. So to reinforce the mounting points, I used some 1/4" thick x 3/4" wide aluminum flat stock and made two 3" pieces, and hammered them into the C-channel, then drilled the mounting holes. This should help with some extra support. The aluminum arms are 16" long each for the rear.
This is just a view of the 1/4" x 3/4" flat stock in the C-channel.
Ok, this was the toughest part for the rear. The drob bracket was a piece of 1 1/4" x 1/4" flat stock that was 6" long to start with. The hard part was just figuring the angle and amount of drop, etc, to keep it far enough from the leaf spring, but low enough to allow for the downward angle of the arm holding the mud flap. I used L-brackets that were 2"x2" with holes that were 1 1/8" apart on each arm. Im using 1/4" diameter bolts with lock nuts holding the L-brackets to the drop brackets, self tapping screws for the drop brackets to the frames, and eventually 1/4" detent pins for the quick releases. From the front of the rear shackle box to the trailing edge of the L-bracket is 6 1/4".
View of the clearance b/w the arm and the leaf spring, which is like 2 1/4" at the lowest point or so, which near the rear of the leaf spring is plenty.
Heres sort of what it will look like when installed. Thats an 11"x17" piece of copy paper hanging from the bracket. The flaps will be 12"x18".
As of now, the parts are disassembled and primed ready for black paint. The drop brackets have been trimmed of excess aluminum for esthetics. The downward angle of the rear arms was provided by a hammer, after the drop brackets were attached to the "frame". The front hangers will be much simpler, as they will be L-brackets simply mounted to the "frame" and the arms extending outward...no drop brackets needed. Hope this helps anyone interested.
*sorry for the quality of pictures...Im using a cell phone to take the pics when I can.
SixLug
OK, got some more work done. The rears are finished, except for adding the mudflaps themselves. They are painted though and Im going to give them a few days to cure before putting them together while I wait on the flaps.
rear bracket parts finished and painted.
how they will be assembled.
Here are the front brackets. They were much simpler to make and mount, as there are no drop brackets needed. The front arms, with L-brackets installed, are 17" long altogether. (you can see my note for the front brackets: "Turn wheels all the way and measure." With the wheels at full lock, there will be no contact with the tires and mudflaps.)
How they are mounted. The mounting points put the arms directly below the very front of the pinch seam, shown below.
Showing how they look from behind. As you can see, with the flaps installed they will give complete coverage of the tires.
Then next three pictures are mock ups with an 11" x 17" piece of paper, and again, the flaps will be 12" x 18".
Front brackets primed and ready for paint tomorrow. Ill update when I get more done.
A side note: If the flaps happen to put too much stress on the arms, etc, I have figured out a way that I will add one more L-bracket to each out towards the edges. The L will face forward, but I will bend up the tip to make sort of a J facing forward, like a bucket or something, that will support the weight of the flaps. A small slot cut into the flaps at this point will allow them to be slipped over the upright of the J and into place. If you have no idea what Im talking about, Ill show you with pictures later...ha.
SixLug
FIN!
Finally got them done. I dont have any pics of the last part of the process. It was basically just me attaching the flaps to the brackets and cutting the flaps to size, etc. Simple, but time consuming.
I freakin LOVE the way it looks, and it makes it a bit more unique to all other XJs out there...so to all you haters...:ar15: ha ha...
Pics...(all cell phone, sorry again. The first two have a dif. filter going on, thats why they are blue.)
milo12
Those look great. Thanks for posting the pictures. I am definitely doing that for my truck. I have bought mudflaps but they are just too small and don't do much.
SixLug
No prob, glad they might help. Let me know if you need any other info.
Big Daddy, we dont have laws in TN either...I just dig the look. Ha ha. Plus I appreciate their function.
Photog
If you are actually trying to keep mud, etc. off the truck, then I suspect you may be wheeling with these mounted?
Don't back up against any rocks. They will get pinched between tire and rock, and get pulled right off. This happened to me, with the factory mudflaps on my 1st Gen 4Runner.
You should have no problems going forward.
They look great.
S
Scenic WonderRunner
Guest
They look great.
That has happened to me twice. With my right front mud flap. No spotter, and backing up, and squeezed between a rock. I hate it when that happens!
I have toyed with the idea of drilling a very small hole in one of the "O's" in my "TOYOTA" front mudflaps. Then using washers and an eye bolt. Then I could hook onto the mudflap and either tie or wire it up high to my rock sliders. My rear mud flaps are fine. It's my front's that hang way down low. I love having them though. I've been without that right front on a long muddy trail, and the whole passenger side of the SWR got wiped out by mud!
Great Idea...Exrunner!
OverlandZJ
They look good. I'v been wanting a set since i saw a pic of some on Dr Moab's rig at NAXJA which are made by Rocky Road.
I'll be making a set shortly that will be quick release with a pin on each side.
SixLug
They look great.
They are quick release, so I can take them off when I wheel. For normal back and gravle roads, I can leave them off.
zhukoveli
