Allegheny trailers?
Incusus
Is anyone familiar with Allegheny trailers? I gather they specialize in creating heavy-duty frames for utility companies, the few I've found via google seem to be pretty beefy.
I have a guy offering me a 4x8' Allegheny for a negotiable $150. All he can tell me is it has a pintle, seems to be made of I-beams, is rated for a #3000 load, has decent tires. He's an old farmer who bought it for the pickup bed that was on it and has no way of taking a photo for me.
Is this a worthy basis for a trailer build? Too beefy? Should I drive the 60 miles to look, or just pass..?
Yes, I know. Not much info to go on....
Titanpat57
I concur with the fine Dr. SSeaman...150$ for a frame ready for 1-1/2 tons is well worth it. 4x8 is also a great starting point.....have the guy send you a pic before you drive out there.
tommudd
seems like it would be worth driving 60 miles to check it out, what do you have to lose? If you pass let me know:ylsmoke:
sseaman
I would start at $150, if it is rough shape you can always go lower, you might even be able to make a few bucks reselling if you don't want to keep it.
Incusus
If it's got a title it's worth 150.00
Don't know about anywhere else, but in Ohio trailers aren't titled, just registered/plated.
I went for a look today, franky the condition was better than I expected, but it was heavier/larger than I thought as well. It seems to be well made.
It was made to carry a full 8' ford pickup bed, is a full 12' from bumper to lunette, 7 3/4 feet long at the bed, and is 3 1/2 feet wide. The axle is 4 1/2 feet and 3.5" in diameter. The lunette is 22 inches high, so that would have to be changed. The stamp on the bed says it's #1200 empty with an #1800 capacity. I assume the bed was probably 3-400 pounds, so that makes the trailer about 800 pounds as is.
on the good side, its got a parking brake, is pretty much rust free, has the same bolt pattern as the wheels on the Trooper, and has a clearance of 16" at the frame.
the downside is weight (I think- is this a good weight??), the fact I would want to shorten the frame by a couple of feet, and I may need to redo the lunette and lower it down.
I guess the question now is, is this a good start for a budget build?
Here's a few pics, I'd like some educated opinions, thanks!
Titanpat57
It looks built like a brick ******** house...I'd say SCORE!!
Do you want to do just a tub trailer, do you want to do an enclosed with tent on top, do you need something that's multi-purpose? I'd say minimum loose the back bumper, cut a bunch of steel off the tongue, and do a SOA.
Write down the needs v. wants x budget...see what you come up with!!!
Good Luck, Pat:victory:
Incusus
I've been thinking hard... I ran the budget and I think I need to hold off on a trailer build until next summer.
Thanks for the input, sorry to run you around like that. Trailer is available in sw ohio if you're interested. I'm, of course, no relation to seller, but I can pass his info on if anyone is interested.
Houie
