mopar performance parts for Jeep JK
haven
Here's a list of Jeep factory-authorized parts that let you turn your Wrangler X into a facsimile of the Rubicon. (Unfortunately, if you have to pay someone to install the parts, it's cheaper to buy the Rubicon already assembled from your local Jeep dealer.)
Chip Haven
source: http://www.mopar-accessories.com
source: http://www.mopar.com/performance/trail/index.html
Sway Bar Disconnect
Sway Bar with Power Disconnect
Part Number: 82210218
$1,410.00
Skid Plate for electronic sway bar disconnect
Part Number: 82210401
$246.00
Body armor
Rock Rails
Part Number: 82210586
$317.00
Bumper and winch
Off-Road Front Bumper w/ winch mount
Part Number: 82209740AD
$587.00
Warn 9.5ti Thermometric 9,500-lb pull Winches
Part Number: 82209325AB
$1,510.00
Off-Road Rear Bumper
Part Number: 82211718
$557.00
Spare Tire Carrier, up to 37" tire
Part Number: 82211832
Use with Off Road Rear Bumper 82211718
$502.00
Rubicon Axles
Dana 44 Front axle for Rubicon
4.10 gears, locking differential, no brakes
Part No. P5155252
$2650
Dana 44 Rear axle for Rubicon
4.10 Ratio, Locking Differential
P5153826AB
$1640
Suspension kits
2 inch Lift Kit
uses longer springs, brackets, and shocks
makes room for 35" tires
works with Electronic Stability Program (ESP)
stock wheels and tires can be used
Part Number: P5155207
$1385
Long arm 4.5 inch lift kit
including long-arm control arms, u-joint drive shafts, Bilstein shocks
makes enough room for 37" tires
Part Number: P5155075
$4650
Axles for J8 Military vehicle
Mopar Jeep JK Rear Locked Dana 60 Axle
Part Number: P5155083
includes limited slip diff, 5 on 5.5 inch hubs, leaf spring mounts
disc brakes from Dodge pickup, 13.8 inch rotors
needs 17 inch rims to clear the rotors ( need to confirm)
$2995 at Quadratec
a version with rear locker is available, too, and $200 cheaper
Mopar Military Spec Front Dana 44 Axle Assembly
front axle tube is 25% thicker than standard Dana 44
includes Dodge truck 13" rotors and brakes, 5 on 5.5" hubs
open differential, 4.10 to 1 gears
Part No: P5155084
$4495 at Quadratec
Engine for J8 military vehicle
VM Motori 2.8L four cylinder turbo diesel
174 hp and 339 ft-lbs
5 speed automatic transmission
planned, maybe only available through AEV
no part number or price yet
Air intake for J8 military vehicle
opening mounted on the hood, includes better air filter
planned, no part number or price yet
Bigjerm
SE Expedition Society
I think its cool Jeep is offering parts but $1,300 for 2" of lift? Yikes... 2.5" lift from Teraflex can be had for $264.
But some folks are about the brand (and hopefully no warranty issues) so I guess the price is ok for them.
mmccurdy
It gets worse... the Mopar lifts are actually just re-branded Rubicon Express kits, which are nice enough kits, but they go for something like half the price with RE stickers on them :Wow1:
There is some debate about whether these accessories (many of them anyway) will let you retain your factory warranty. Technically, they are classified as "Mopar Performance" accessories, which are not covered by the warranty, according to the fine print. Some folks report that their installing dealerships have stated that the warranty will remain intact, but it would make me nervous personally... but then again, my warranty expired thousands of miles ago :smiley_drive:
Bigjerm
I hear ya on the warranty. I knew the 4" lift was the RE lift, didn't know the 2" was... OUCH on those prices.
The whole warranty issue is old news to me. I mean anyone who mods a car faces that issue. Obviously putting a lift on isn't going to deny getting your leaky top fixed but it might if your drive shaft fails.
iStan814
