Changing Room for Trailer
adventureduo
Dave Druck [KI6LBB]
We had a the changing room for our Mombasa Expedition Series tent before on the Cruiser, but since we moved the tent down to the trailer i never really thought it would work. So today i was busy doing nothing and figured i'd give it shot and see how it would work with the trailer width, height and all that.
Works well with only a minor head tilt to get under the tent platform. The window appears perfectly like it was made for the trailer height.
It will work good for privacy, something that yosh feels she's lacking now that the SMB is gone.
Once inside you can sit on a chair and have plenty of room.
I was pleasantly surprised that it covered both front and back sections of the cargo side box on the trailer. This is one of the things i was concerned about. With this deployed you could technically use the box door as a table if you wanted too.
Also if she only needs privacy from one side of camp you can deploy just half of the room.
Note: We won't be using this to have a party under , nor will we be eating under this... we have awnings for that.. but this will work perfect just for what it is... a "changing room".
Thanks to Mel at Mombasa for hooking us up with a new changing room. :) The new green version is a nice contrast with the tan canvas and it seems thicker than the old tan version.
Titanpat57
Hi,
Would you mind posting a link? I have the same color lower dressing room as your previous one, and totally dig the dark green.
Thanks, Pat
Ca. Bowhunter
Look's good Dave ,
Here is what Rhonda did with ours she cut four pieces of 3/4 inch pvc and found four 90 degree elbows to make a frame that sits inside the tent to hold the walls from blowing around then she has sewn four quick release buckles and used the extra fabric to make a floor so you can change with out getting your feet dirty.
Randy & Rhonda
Houie
