I bought this trailer from a guy a couple of blocks over from my place so I could pack a bit more gear for our may long weekend run. It currently has a samuri rear axle and the frame is very light duty. So today I bought a 2000 lb trailer axle with new leaf springs and then went to the surplus steel place and bought some 2x2 3/16ths wall square tubing. The plan is to beef it up and build a small camper trailer approx 8 feet long by 5 feet wide and roughly 5 feet high. The walls will be 1/4 plywood in and out with rigid insulation sandwiched inside. The tires are 31 inch by 10.5 by 15.
