Center Console for almost everyone.
TEJASYOTA
I was web searching RAM Mounts to check out mounts for my phone and future GPS unit.
And saw this....
Talk about flexibility.
Only concern is that it is (9-inches) wide.
Too wide for the earlier Tacomas...only a 6.5-inch would work.
Very cool stuff, either way...check it out.
RAM Mount Center Console - click here
off-roader
Doesn't your taco have a floor shifter versus a steering column shifter? :confused:
This wouldn't work in my Montero because it has a floor shifter plus the e-brake is also there :(
Connie
Day walker, Overland Certified OC0013
That IS cool! I watched the assembly three times. I especially like the armrest addition.
TEJASYOTA
I never said I bought it or installed it....hence the comment about 6.5-inches of clearance between seats. ;)
Now if they made one for 6.5", I would seriously look at it, instead of getting a Tuffy center console. That RAM unit is WAY more configurable than Tuffy.
edit - - forgot to say, yes I do have a floor shifter :)
off-roader
OK. Was wondering about that.
TEJASYOTA
I like it but it wouldn't work in my Kj. I have a floor shifter and e brake there.
There are 4 main lengths of the boxes and I bet the main base can be modified to make it fit trucks with floor shifters. Hence all the different mount points available.
02TahoeMD
These center consoles are really expensive new. If you want to do this, shop eBay a bit, you can find a center console used for as low as $40. Then you only have to spend money buying new trim plates to match your application.
Here is mine when I first finished it off
And the current configuration
Underneath the paint....is the same system as a RAM mount filling the gap between floor console and the dash.
off_to
