Xantrex XPower Inverter 1000 (XP1000) @ Costco
craig333
I went with the xantrex 1200 plus so I could use the remote switch.
craig333
Safety
Normally I'm one to go "we don't need no stinking manuals" but with an appliance thats rated at 120 amps max it pays to be safe. Notice they recommend 2 guage wire at no more that 5' length. Notice the huge fuse I have in my pic (purchased at westmarine). They recommend a 150 amp fuse.
While these units are manufactured in China Xantrex is a Canadian company and has excellent manuals.
http://www.xantrex.com/web/id/837/docserve.aspx
By locating mine near the camper battery I was able to use automotive battery wires instead of having to make custom cables. I also used heavy shrink tubing near the terminals just to be extra safe.
evldave
Expedition Trophy Winner
On my 1kW inverter I used 2 GA welding cable and mounted the inverter behind the back seat of my suburban (total length was maybe 10-15')...i had 150A fuse...ran it at full 1kW for awhile and checked the cables...minimal heat, so left it that way for a bunch of years.
The advantage of using welding cable is it water/gas/oil resistant, so I was able to run it along the frame rails w/o worrying about it decaying over time. Was like $30 for 25' of both red & black
CMARJEEP
Bump.
I got the 1000w Xantrex inverter for $10 at the Costco in Las Vegas. I have been pissed at myself for not buying the whole pallet up. :(
Anyway I want to mount it in the rear cargo area of my Grand Cherokee. The manual concerned me when it said to not run it longer than 5' from the battery. What gauge cable do you suggest and what is a good way to run the cable from the battery to the inverter in the back? Should it be ran along the frame rails and then up through the floor to where it is mounted or through the cab?
Thanks!
zhukoveli
