adrenaline503
So I installed a Maxima electric fan to replace the clutch fan.  Driving around town everything is great, the AC runs cooler at stops and the throttle response is a bit smoother.  However, on steep grades at low speeds I rapidly start to overheat.  Once I turn the heater on the temperature quickly drops.  I have narrowed it down to the following possibilities:
1. The Maxima fan has 2 speeds, low and high. The fan has three power wires. I might have it wired to the low setting but I have been unsuccessful in locating a wiring diagram that clearly shows which wires go to what speeds. Or maybe its multiple wires for high?
2. The e-fan thermostat isn't coming on at the right time. It actuates the fan as soon as the temp goes above "normal" so it seems fine.
3. My cooling system has a problem. I don't think this is the case. Its fine around town and was fine before the install.
4. The e-fan isn't capable of moving enough air to keep the truck cool enough and I am screwed.
So, any other alternate ideas? Anyone know how a Maxima fan is wired?
Thanks
Thanks
