SeaRubi
I really like the pushbutton operation of the swaybar disconnect, but it's not without a glitch: over 10mph it tries to reconnect itself. If you find yourself driving moderately fast on corrugated roads or a gently rolling trail, you can start with it disconnected and know that it won't reconnect because the axle doesn't sit still long enough and the light just blinks at you on the dashboard.
I'm worried that this will damage the device, and also want to be able to arm/disarm the disconnect when I want to ... not some alert on speed! Has anyone found a clever way around this? It seems like it would be fairly easy to rewire with a toggle and a simple circuit. Does the motor just work on polarity reversal to engage/disengage?
cheers
ike
cheers
ike
