For Sale: Technitop Roof Top Tent (RTT)
Echo_29
Sold: Technitop Roof Top Tent (RTT)
Technitop RTT
Overland Journal, Editors Choice, Spring 2007
Used 33 nights in 16 months.
Tent is in great shape. No leaks, tears, stains or blemishes.
Two piece Ladder, PVC cover, Fly Poles, Fly, mattress and cover.
PVC tent cover is fading due to sun and has two small wear holes that could be easily patched from the inside (see photo), but still keeps tent clean and dry.
Dimensions :
Length box (closed) - 43 inches
Length box (open) - 86 inches
Width - 51 inches
Height of box - 11 inches
Weight (no ladders) - 114 lbs
For more info see:
http://www.sleeoffroad.com/products...ww.sleeoffroad.com/products/...top_detail.htm
Retailed for $1695 plus tax.
$1100.00 picked up.
Tent is located in Los Angeles.
1/8" hole at both sides of rear cover
SoCal_80
Was hoping you might be able to measure the width of the tent for me. I know Slee says it is 51 in, but i am hoping that it the widest point at the top when it is opened. I am hoping it narrower at the base so it might fit my rack. Thanks!
Echo_29
How tall are the rails on the Hannibal, that way I'll know when to measure.
The tent and truck are down at my friends shop so I'll have to get back to you tomorrow night after I swing by.
go4aryd
As an Technitop owner, the 51" is the width of the plastic - however, the sides are tapered only about 1.5 inches or so all the way around. If your Hanibal rack is 6 inches high, you would need to mount it on top of the rack.
I bought mine, then had to figure out how to make it work - was very worth it for me.
go4aryd
It is actually not that easy to measure by yourself, as the chamfered edges are a little tough - mine is actually right on at 51" wide by 43" collapsed, per spec.
...and bump for a sweet tent.
Echo_29
Updated Photos
I've updated the original post with additional information and photos.
The awning has sold.
OMC
Thanks!
Just wanted to publicly say thanks to Echo_29 and his better half for making the purchase of the Technitop awning a pleasant, quick and simple transaction. It arrived via UPS today very well packaged and exactly as it had been described in PMs. Great to have done business with you.
OMC
zhukoveli
