HAM: Need some Coax help from those in the know.
Clark White
I have a Yaesu 7800R and a Diamond Antenna SG7900. I will be mounting the antenna on the side of my roof rack. I want (I'm told it is the best/close too?) to use RG8X Coax and am planning on building my own cable (I do this every day for a living, so I am confident I can do a good job). However, at work we look in a parts listing for the plane, order a mil-spec part, and never have to research manufacturer or specific versions, so while I can do the work, I'm at a loss what parts to order or where to get them from :smilies27. I know I need a UHF/PL-259 connector on the radio end. I then want to put a panel mount connector in the roof (rather then running through door seals or just having a wire pass through). What panel mount should I use, and what connectors go with that? I thought I could just use an 90* SO-239 (like factory Diamond Antenna coax), but I cant find what connector will thread on to an SO-239 besides the antenna. Then for the antenna, I know I need an SO-239, but I would like to get a 90* like what comes on the factory Diamond Antenna coax, any idea where I can get those from? I'm assuming I want gold plated for these, but I don't know enough about them to know which manufacturer is the best, which versions are best, etc.
Thanks!
Clark
Note: On the planes, we use RG-178? and either mini UHF or BNC, so I don't have anything to compare specific connectors to.
SunTzuNephew
Thanks!
Clark
Not the way I'd do it but how about one of these?
http://www.powerwerx.com/rf-adapters/bulkhead-uhf-female-to-uhf-female-rf-7625.html
Powerwerx is a good place to do business with, also
gary in ohio
I have a Yaesu 7800R and a Diamond Antenna SG7900. I will be mounting the antenna on the side of my roof rack..
Typically you DONT need to make up your own UHF connector coax assembly., Get a pre-fabbed unit. While the name of the connector is UHF and its similar in size to a pl259 connector you really dont want to screw it into an so239 plug. The "UHF antenna" connector is actually longer. a SO239 is not waterproof. Here is a NMO version of the cable assembly. http://cgi.ebay.com/Antenex-3-4-Hol...in_0?hash=item587f32fda0&_trksid=p3286.c0.m14
Since your going through the roof, USE an NMO mount and if your need a UHF mount, use the adapter. Its going to be a BIG pain trying to keep water out of a panel mount and most s0239 panels are not designed to be outdoors.
The factory diamond antennas is not a standard 90deg connector, its a UHF specific mount for mobile. use.
Normally for UHF/VHF you dont use RG8/RG8x but within a vehicle it works fine for the short distances you need. For home use when your over 50ft lmr400 or rg213/9913 is preferred
Clemtiger84
