Extending positive cable for Diehard Platinum group34 battery
juicebox
So I just picked up a group34 Platinum battery for my Tacoma and the battery terminals are on the wrong side, I knew this when I bought it but the one that Sears recommends for the 3.4L v6 is not as powerful as this one.
I knew also that I would have to make a new battery hold-down, I figured the cable would reach across the top of the battery and it does not. I know this battery is popular for tacomas and the like so I was wondering what good ideas you guys had for me as to how I can simply extend the positive cable about 3-4". I am pretty sure I saw someone put a piece of flat copper about an 1.5 inches wide and 4 inches long and just drilled holes in each side, but I can't find that anywhere.
Also, I don't know what is the best way to do it. I want it to be cheap, but I would rather pay if I need to in order to avoid some ghetto-fab job that is borderline dangerous. Any suggestions are helpful. :smiley_drive:
juicebox
Anyone?
My old battery is most definitely on it's way out and I need to figure out how I can get this new battery in.
juicebox
no 34R in the platinum. :(
I think I am just going to go to home depot and figure out some sort of ghetto-fab job for the time being.
ntsqd
Heretic Car Camper
That is as close as it gets? putting it in reversed is worse?
What I would suggest is replacing the battery terminal end with an eyelet. Make up, or have a local battery store make up a short cable to run from the battery terminal to where you can mount a HD isolated stud, and bring the now modified old cable to the stud as well. This is roughly what I did on my FJ60, but for a different reason. The isolated stud came from the local West Marine store.
Am I missing something? Just make a new cable. "O" gage wire is about a buck a foot and ends are about two bucks each. I would think you could do the whole thing for about 25.00. In the PNW we have a battery shop Pacific Power that has all this stuff.
mdnky
They actually make an "cable end replacement" that's based on a splice setup with about six to ten inches of cable. You basically cut the old end off, strip 1/4" of insulation away, and attach the new part via a solid butt connection that is mechanically crimped. Not a perfect solution (at least not in perfectionists eyes), but usable.
You can find them at auto parts stores and Sears also has them in their Auto Centers. They run about $5 to $10 each. That might work if you're looking for a quick, easy fix until you can replace all the cables properly. Otherwise, I'd do as a few have already suggested. Get some good quality 0 gauge cable and some ends to make your own.
PNWav
