Laptop mount for 2008 Sportsmobile
1leglance
I know there has to be some SMB owner around here who has a laptop installed...and if so what mount did you use?
I am curently using a Jeniko floor mount in my FJ Cruiser but not sure if that is the best solution on a van with the need to remove the doghouse. Unless I install the mount on the doghouse itself.
http://www.jeniko.com/cfl800-floor-mount-p-1.html?sessId=7e77a4110fd9c4e7b73b7d2de9e9ad06
And then there is the concern about making sure it isn't in the way of anyone's legs who might transfer from a wheelchair into the drivers seat (from the cargo area).
I know there are companies like Ram & Panavise that make all kinds of bits & pieces but I figured it would be good to check in here first.
spencyg
This Space For Rent
If the 2008 doghouse is anything like the 1986 doghouse, its a no-go. Mine is made of fiberglass and isn't nearly rigid enough to support the torque imposed by the mount...let alone the mount AND the laptop. I have my Jeniko mounted to the floor by the driver seat...a perfect place for me, but it does significantly hamper access to the rear from the driver seat. I don't see any other solution however with the laptop. Before too long I'll have a Boomer-puter and a flat panel display and will forget entirely about a laptop. For now, I live with the rear access limitations.
Spence
1leglance
Blatantly stolen from Joaquin's Casa page.
http://www.overlandhardware.com/ca-specs.html
I never get tired of looking at that rig and I can't wait to see it up & running again...
Looks like he cut part of the dash away.
http://www.fordvehicles.com/trucks/eseries/gallery/photos/interior/
looks like I might be able to do something with either Ram or Panivise parts on the top of the doghouse or maybe just bring a flat/bent plate out from between the dash & doghouse to place the laptop just in front of the ac controls & radio
seth.c96
