Dual Alternators?
muddyluxury
Here is my thought,
Set up a second alternator on my Jeep, and have that second alternator power a dual battery system that is completly isolated from the main power of the truck.
I would end up with: 2 alternators, main and aux. The main alternator would power the jeep and all its little things wired into it.
The aux alternater would power a battery under the hood for a winch and a few other misc things. and a battery in the cargo area that would power other things.
These batteries would be isolated from each other, so i could run the battery in the cargo space down at camp. And still maintain full power in the battery under the hood for the ability to self jump if i have to.
so here is the questions:
1. can i run a dual alternator setup with the aux alternator completly isolated with out frying the two batteries?
2. If i have the 2 aux batteries isolated to prevent them from drawing off each other, can i still have it set up when i start the truck it charges both batteries? all that while maintaining the ability to allow the batteries to work together if needed?
3 has anybody else ever done something like this here??
SunTzuNephew
Here is my thought,
Yes you can
Yes you can
Yes. It's done all the time on boats, where there is a starting bank of batteries and a house bank of batteries. The only significant difference is two alternators, but as long as the only common point is the ground it will work.
Houie
