a few questions for Mr. John----
1) What bushings/bolts do I need to swap over to my truck to make it work?
"From Mr. Slee:
The bottom bushing ID is 19mm but on the N101 the width is 45mm and the N74L is 40mm. So you would need to use the N101 bottom bushing.
The top pin is 17mm on the N101 and 14mm on the N74L. The index washer lip is 26mm on the N101 and 22mm on the N74L.
So on the top you need to use the N101's washers and hardware, but you need to use the poly bushings from the N74L."
2) I'm running 33.4" (295/75) BFG AT's , how low will I need to put the bump stops?
To protect the shocks during compression, I confirmed the same number another member did previously...1/2" bump stop extension is all that was needed. I decided initially to run 2" bumpstops from the day I added 35-inch tires. This was only for rubbing purposes. I did not change the stops after adding the L's. We did recently drop to a 1/2", though I've not been on the trail to test yet. I'm concerned that the rubbing will bug me.
3) How much added rear flex will I get with the N74L over stock shocks?
For YOUR setup:
*You are in a better spot! Having 33's you don't need to worry about rubbing. You 1/2" bump stop it you'll gain 2.1" travel (or a touch over 3-inches wheel travel). It's the wheel travel that counts. Pictures don't lie. The difference is mainly in the form oif droop which is what we need on our lifted rigs.
Here's another thought on this......think about all the slams from the non-IFS crowd about the lack of FRONT wheel travel on the 100. Compared to the 80 the 100 has 3" less front travel. Imagine gaining that travel up front on a 100. It'd be a BIG difference, right? Everyone would praise the gains. Well, you can add it to the back of a 100 and it makes a big difference as well. Wheels are on the ground FAR more often. Pics don't lie!
4) What do I use upfront? the normal 100 OME shocks?
No change.
5) Was is the same cost or a little more than standard OME shocks for the 100's?
They're the same or nearly the same. I didn't look them up.
Thanks, and if anybody knows the answers feel free to chime in! Blown shock in the rear don't feel to good.
