Looking for a recommended light for HID conversion
milo12
What is a well made halogen light with a good light pattern and reasonable price?
I am considering picking up a couple lights and converting them to HID. Here is a link to 70 watt HID ballast and bulbs. 70 watts is crazy bright. I think if I started with a light that was well made and has a good light pattern I would end up with some nice lights.
http://www.dxhid.com/70wattxenon.htm#430733366
dustboy
So, are you converting your factory headlights to HID or adding some rally lights that you will convert?
If you're adding lights don't waste your money and time, just get a few of these:
El cheapo HID off road lights
I got mine on sale for $100 each, they go on sale periodically and you might be able to find a better deal elsewhere on the web. A lot of guys have been using them for a while now and they seem to hold up, and they are friggin flamethrowers. They also have a 4" version that is a little cheaper.
D
DEEZLPWR
Guest
i actually saw these and it looked to be a good deal, i tihnk i will get a few :D
milo12
I agree the Hella 4000's seem to be the way to go. I will get three. 1 "Euro Beam" for the center and 2 "Cornering Beam".
Euro Beam - stock throws light over 1500 feet.
http://cat.hella.com/hella232/jsp/search/advanced/Frameset_ButtonBar_Bottom.jsp?nologin=yes&currentObjectId=CA@USAData@PR@H12560021
Cornering Beam - stock nice wide deep pattern
http://cat.hella.com/hella232/jsp/search/advanced/Frameset_ButtonBar_Bottom.jsp?nologin=yes&currentObjectId=CA@USAData@PR@H12560051
Those patterns shown above are with the stock halogen bulb. With the HID's it should be much brighter.:Wow1:
Now to decide whether I want the 70 watt HID or the 55 watt HID.
Edit: Sorry the links don't work. If you are interested in the patterns go to http://www.hellausa.com and follow the links to the 4000's
milo12
Here is the numbers on what I am working on. For the true geeks out there.:victory:
I decided I am going to use the 70 watt HID in the center Euro Beam light, and 55 watt HID's in the 2 Cornering Beam lights.
3 Hella 4000 lights with wiring harnesses - $416
1 70 watt HID conversion kit - $150
2 - 55 watt HID conversion kits - $65
Total $631
So what did $631 get me.
The 3 Hella 4000 lights with the stock halogen bulbs put out 3600 lumens.
The 3 Hella 4000 lights with 1 70w and 2-55w HID's put out 16,250 lumens.:Wow1:
That is 4.5 times more light for less than the price of 1 quality HID light. The Hella 4000 is available from Hella as a 35 watt HID for around $800.
Heimz
Just throwing it out there, but you might want to make your own harness with relay and switch for the Hella Lights. One, its cheaper, but more importantly is that I know of two seperate incidents where the Hella 4000 harness caught fire and burned up the engine bay. My friend used a 2 liter of 7up as a fire extinguisher- shook it up and sprayed'er down. It scorched his ABS, 4WD actuator, and driver side fender/hood.
The Hella HID conversions are BRIGHT, and I have also heard of good things about the Pro Comp 9" lights with HID conversion.
xander69
