My 87 runner
yeler
87 4 Runner
paid $700.00 and came with a blown motor :Wow1:
22RE
W56
Dual Marlin cases w 4.7
Twin shifters
4X inovations crossmember/skid plate
5.29 gears
Aussie lockers front and rear
Solid axle swap
Billstein 5150 shocks front and rear
35" Cooper STT
63" Chevt rears
Rears up front custom pack
Marlin front rear bomper
Marlin rock sliders
All Pro internal cage
Custom swing out spare tire carrier
Winch
1200w stereo
half doors
couple pics
full build here
http://board.marlincrawler.com/index.php?topic=31725.0
yeler
and here is it all done . . . for now, lol new 31'' LED on roof rack, 14" LED on top of winch 2 oval LED on front bumper 2 on rear bumper, rear sway bar from Jeep Grand Cherokee added with quick disconnect, remote winch switch, new stereo and CB added, shovel, Hi Lift and CB antenna on roof rack, new spare / fuel and water swing out rack, new driver seat and 3'' lap belt finished,
yeler
six years later LOL i lost my job after 20 years and am a disabled Marine so the Runner has been sitting in the yard for a while hehehe so a good friend helped me add some much needed add ons
yeler
final list of stuff done to the Devil Dog Runner in no particular order by my friend Tommy it took a long time to do it all since he was kind enough to work on it in his free time, and for that I salute him :safari-rig:
Bumper supports
Straighten front bumper
LED light/wiring/brackets
Polish turn signals
Rock lights install
Install steering stabilizer
Backing plate eliminator
U bolts
Wheel bearings/seals
Bump stops
Shock mounts
Roof rack
Adjust timing
Hi Lift mount
CB antenna
Clutch
Cross-member
Center council fuse panel
Seats/seat belts switch panel
Stereo/CB install
Speaker box LED's
Amp
Mirrors
1/2 door window covers
CB speaker
PA speaker
U-joints
Sway bar and disconnect
Re-mount rear shocks
Rebuild frame ends
Parking brake cable
Rear bumper
Swing out tire carrier
Rear LED's
Lic. plate holder & LED"s
Jerry can mounts
Tire iron holder
There are more things on the list but that's good enough you get it he did allot of work :bowdown:
yeler
Having these windows made on the 1st of may gonna cost $480.00 + tax. these are going to be awesome
yeler
The Devil Dog Runner, is a 2 tone Maroon and Black 1987 Toyota 4 Runner equipped with
Marlin Crawler front bumper w/ stinger
5500lb Super Winch winch
W/14'' LED on top
motor 22RE
Trans W56
dual cases 2.3 front
Marlin Crawler 4.7 rear case rotated 10*
Marlin Crawler 27 spline chrome molly output shaft
Marlin Crawler triple drilled flanges
Marlin Crawler low profile drain plugs
Marlin Crawler dual t case mounts
customized 4 X innovations cross member/skid plate
Marlin Crawler triple T case shifters
square front drive line
Marlin Crawler chrome molly axles in front
Marlin Crawler Steering Stabilizer
axles turned for proper Drive line angle
Marlin Crawler vented rotors
5.29 Yukon gears front and rear
locked front and rear with Aussie lockers
Marlin Crawler shock hoops in front and custom mounts in rear
Bilstien 5150 shocks 12'' front and 14'' rear
I run the Rear leaf springs in the front
63'' Chevys in the rear
I have pivoting spring blocks(spring hinge)
custom sway bar (from a 93 Jeep)
Marlin Crawler rock rails
modified Marlin Crawler rear bumper
custom swing out spare/fuel/water holder
custom roof rack with 31'' LED
Hi Lift mount and Shovel mount in roof rack
Marlin Crawler LED rock lights
custom stereo system with speaker box lighting in cab rear cargo area
in cab All Pro cage
half doors w/storage, cup holder and speakers
CB
EQ
4 speaker speaker box and amp
custom Ammo Can armrest center council
12 Volt Guy remote winch switch
35'' Cooper STT's
15'' Pro Comp street locks
in bed storage box
I'm sure I forgot something but Im pretty sure its good to go on just about any trail, final crawl ratio is 223.1
