My Review: One week and a '09 Wrangler Unlimited Rubicon
ExpoMike
So, I thought I would do a write up about my week long rental of a ’09 Jeep Wrangler Unlimited Rubicon. All of the info I present is of my opinion and take them as you will. My wife and I took a trip to the Big Island of Hawaii and originally had our reservation for a Wrangler 4x4 2 door model. Once at the checkout counter, I had made a comment about really liking the 4 door model we had a couple years back on Maui. A few clicks from the manager and I was offered an Unlimited Rubicon for $10 a day more. I didn’t even pause to say yes! I had wanted to try one of these from the day they came out and with my plan of some good offroading on the Big Island, the extras the Rubicon offers was more than welcomed. I chose the bright yellow one they had in the lot. BTW, as a side note, you would be surprised by how many yellow Jeeps are on the Big Island.
We loaded up our bags, which was two full size suitcase, two carryon size cases and a 12 pack size cooler. Folding down the rear seats made swallowing up the luggage no problem. I give Jeep credit for a well designed rear fold down seat in the Unlimited. First they are split, 60/40 IIRC and the great design of the folding headrests, which retract back as the back seat lays flat to the floor. Nothing to remove or mess with, it just works. I wish we had this feature in our Cherokee. This was also the first time I have had a JK series Wrangler with the hardtop as our previous rentals (2 and 4 door models) were soft tops. As we got on the road, I noticed that the hardtop made it much quieter inside the previous soft top models we had rented. It also kept it cooler and more secure to boot. During the week we did test out the removable roof panels over the driver and passenger areas. They removed fairly quickly and with the rear seat up and nothing in the back, fit in the rear cargo area, stacked flat on the floor. This was even with the optional sub woofer this model had. I could see it being a pain to figure out where to put them if you had cargo in the back but I am sure someone in the aftermarket makes (or should) a holder that would stand them upright or hung off the spare tire.
As the week progressed, different likes and dislikes emerged. I found the ergonomics from the driver spot to be very well laid out. Everything was clear and easy to get to. During the week, we drove over 1100 miles, with about 150 of those offroad. Both my wife and I, who are heavier than average, that the front seats were comfortable on the road. Our longest nonstop stint was about 140 miles and we did not feel fatigued when we got out. Offroad was a little different. We both noted that after an hour bouncing around, the seat bottoms felt too firm. I don’t know if the density is too high and when you start moving around but we have never felt this way about our Cherokee seats. The Wrangler ones may need more time to break in (rig did have 15,000 miles). Something else that surprised me was the Goodyear MT/R tires, standard on the Rubicon, were not nearly as loud as I feared they might be. There is a little noise from them but nothing that felt tiring over time. Offroad they worked great. We never had any traction issues and being that a lot of the area is sharp, volcanic rock, they just seemed to take everything with strides. I am not sure I would have felt as comfortable on some of the trails, had the tires been the lower models they put on the non Rubicon editions. I do have to note that on road, in the wet, the MT/R’s did not give me the same confidence of other tires. We got caught in some rain coming back to the resort one night, on a twisty area of the highway. Knowing these were not wet performance tires, I had been driving very easily and cautiously but on one tight turn, the backend started to step out. I started to counter steer when I noticed the DSC light flashing. It had caught what was happening even before I had the chance to start reacting to it. As much as I don’t like babysitters when it comes to car control, this system worked very smoothly. This was the only time during the trip the DSC kicked in, so I don’t have any more info on how well it works but for the average driver, I would say it’s not really a hindrance. One thing to note, the DSC is disengaged when you are in low range 4WD. A message on the dash info meter will tell you this, as a reminder.
Now for the offroad opinions. To start, the first thing I did the very first night we got to our room was to bring up the owners manual and read everything about the 4x4 systems. I wanted to make sure I knew how the electric sway bar disconnects work, the front and rear selectable lockers and engaging 4WD and low range. The Rubicon model has a 4:1 low range transfer case and prior to driving this rig, I always thought 4:1 was too low to be any practical use outside of rock crawling. Well, my opinion has changed. I actually found it very useful from allowing steep descents without having to ride the brake to climbing over obstacles with a little more precision. I really could see an advantage if towing a trailer offroad, as you could help keep the trailer from “pushing” you as you went down hills and such. I could even leave it in low range and use 3rd or 4th gear (this was an automatic transmission) and use it as a good trail speed range but knew I could drop it down a gear or two if needed, without having to stop and move the transfer case from high to low. I may have to look at a 4:1 setup for our Cherokee.
Having known the advantages of disconnecting the sway bar on our Cherokee, it truly was nice to hit a button and not have to get out and disconnect anything manually. We actually found we used this feature a lot, not so much because we needed the extra flex but because it road better in the dirt/rocks with it disconnected. Since we did not have a way to air up tires on the trails, we had been driving everywhere at street pressures. At these pressures, it really made the ride rough and jostled you around a lot. With the sway bar disconnected, it was a very noticeable and much welcomed smoothness to driving. This does bring me to one of my dislikes. Jeep saw it fit to only allow the disconnects to work when in a 4WD range and at lower speeds. At approx. 20mph, it would start flashing the sway bar light warning you. I have heard there is an aftermarket fix that changes the computer program to allow this system to work in 2WD. It would be first on my list of mods. This brings me to the next system I like about the Rubicon but wish it was done a little differently.
The selectable front and rear lockers. This was a great system and really allowed us to crawl up areas without any wheel spin, minimizing our footprint on the trail. The system allows rear only or front and rear together. Again, this system only works in a 4WD range. It would have been nice to allow the rear locker to work in 2WD as 4WD wasn’t always needed with the extra traction from the locked rear. There is also a limit to slower speeds to use them, again something I would like to change and there may be an aftermarket solution out there. When used, they worked flawlessly and it was nice to be able to disconnect the front locker while leaving the rear engaged. Climbing up something that required a tight turn, you could feel the front trying to straighten out the steering but a quick hit of the switch, unlock the front and it would steer right where you wanted to. Being this was my first experience with selectable lockers, I would have to say this really gives the best of both worlds, for street and dirt use. I also feel it does limit the impact to the terrain since you tend to not spin the tires as much, if at all.
I know that most offroad enthusiasts feels the need to modify their vehicle, almost out of the box. Many do not really get out and test the vehicles before jumping into lifts, bigger tires, suspension mods and whatnot. I can honestly say that out of the box, the Wrangler Unlimited Rubicon is a top notch rig that for 80% of most people, really doesn’t need any modifications. If your typical trail duties include hard 2 to moderate 3 rated trails (out of 5), it is doubtful you will need to change anything. I feel it is by far the best Jeep, Jeep has ever put out. You can tell that enthusiasts had a very big hand in the design and building of this rig. It is not until you start moving into the more extreme end of the scale, mods would really start to make sense. I think I would be looking at some upgraded armor, to play it safe and wheel the heck out of it. I feel it would have made any trail I have taken in our Cherokee. I typically find the limits are not so much the rig itself but the people inside the rig. I know my wife has her limits well before the rig does. LOL This is not to say there are not improvements to be had but I feel many are not needed but wanted. Each person will need to evaluate their own needs and see what is right for them. If you are truly honest with yourself and your needs, you might find a lot of extras are not really needed in this case.
In closing, I hope my opinions were useful in giving a real world test, not done by marketers or someone trying to sell ad space in one of the publications. I am just sharing what I experience and my opinions. Take them for what they are. I feel I was lucky to get to test out a vehicle that I have wanted to drive for a long time. Would I like to own one? Yes I would but our Cherokee has done everything we have needed it to, so I haven’t felt the need to replace it. If and when the time comes that the Cherokee is no longer viable, the Unlimited Rubicon is on my list to replace it. I have included some pictures we took while out and about. I hope you enjoyed my review and the pictures. Until next time…
Trail Monkey
Adventurer, Overland Certified OC0014
Great writeup Mike, looks like you had a real nice time. To bad you couldnt have brought the Kamparoo.:sombrero:
crawldit
Great write-up. I love my 05 Rubicon SWB, but I am lusting after one of the new 4-Doors. They are very capable straight off the lot, and it's hard to argue with all of the added storage, the stronger axles and the increased width.
ox4mag
Very enjoyable analysis, Mike, and very practical too. Too often I'll see a review of a product that focuses too much on specifications and other jargon that the average consumer has really no interest in. Seeing how it handles and rides in "real world" and in off-highway situations is what is interesting, and your analysis brought home a lot of these points.
So just for curiosity sake, if you had a Rubicon and were looking to start with some mods, what would be the first mod you would make based on your assessment?
JIMBO
:sombrero:I agree pretty much, except the hardtop needs mods to do a great job for temp/sound control !!
Looks like they picked out the right color for you, great writeup !
:costumed-smiley-007:safari-rig::safari-rig: JIMBO
ExpoMike
Thank for the props. Means a lot coming from someone in the mag/e-zine industry.
Hummm.... I would have to think about that for a moment. My guess would be that I would start with replacing hard parts that have been prone to failure or wear. Things like stock control arms, maybe something more durable and less binding, to help keep things from cracking or bending as miles were added. Under body armor, protect what needs to be protected that either the factory made too light or poor design. I haven't checked out a lot of mod for the JK line but I do recall read about the issues people were having with hitting the evap canister. I think there was a relocation kit.
Next would be recovery/protection. Something like an AEV or ARB bumper and winch. Good recovery points front and rear. Then I would look at storage solutions for my needs. I know Gear did a great job with the back end of his JK and I would look at doing something similar.
I do know top on my list, if they are available, some computer reflash to make the disconnects and lockers useable when I wanted them, not as it currently stands. Maybe when I need to replace tires, I might look at a budget boost lift (2") and slightly taller tires. Never hurts to have a little extra clearence.
I still think I could drive one off the lot and be very happy with my Kamparoo in tow, heading out to the areas I like to go. Like I mentioned, in the almost 4 years of wheeling my Cherokee, the Rubicon would have easily gone anywhere I have take it.
Something I forgot to mention in my review was the interior space. We love our Cherokee but the Unlimited just has that extra room in all directions. It doesn't feel as tight inside as the XJ platform. It also allows for rear passengers to actually have legs attached to their bodies and go for a long drive without feeling like you're stuffed in the trunk.
ExpoMike
I am not disagreeing that there could stand some improvement but compared to the soft top, the hardtop wins hands down in this catagory.
We had rented a 4 door and 2 door soft top JK's in two previous trips to Hawaii and between the two of them, logged almost 1500 miles. Prior to renting any of the JK's I had always figured I would by the dual top option, so I could have both. After having the hardtop model, I don't think I would ever use the soft top option. I wouldn't mind doing the half door with the hardtop, if I wanted it opened up a little more.
ox4mag
That's really the beauty of the Rubicon platform. The Rubicon first started with the TJ line with the intent of being able to pretty much handle nearly any terrain right off the dealer lot. The JK Rubicon has built on this and all the mod additions you've suggested are right on. One thing I've found with Jeep vehicles is how poor the underbody protection usually is and you hinted on this.
Anyways, nice job on the analysis. Maybe we need to get you on staff at JPFreek to start doing more of these type reviews! ;)
JIMBO
:sombrero:Yea, I know XJ, I'm just basing my comments on a summer spent in the Nevada heat, (105 deg) and the things I did to the hardtop to make the inside more "livable"
A soft top would have been Unlivable, in that kinda heat and sun concentration on the Black hardtop, would have made the inside reach 115/120 deg. without insulation and A/C
ExpoMike
Hummm... funny you say this. I have been told by many, many people who have read stories, trip reviews, product reviews, etc. that I should be a writer. I like to tell stories, make the person reading it, feel like they were the one having the experience.
If serious, PM me and we can talk offline. :ylsmoke:
inked33
thanks for the review....i am hopefully going to be picking one up next year. this is exactly the information ive been looking for
ox4mag
PM sent. :)
StumpXJ
SE Expedition Society
Nice review Mike!
I love the Rubi 4:1 in my XJ. Makes all the difference in the world, primarily in those situations where you mentioned. Definitely a great upgrade.
~James
Ronct110
XJ Mike, looks like you had a great time w/'09 Wrangler Unlimited Rubicon.
Where did you wheel in the Big Island; in the pictures, is that mana rd. Thanks! I am planning a trip next year.
Seriousman
Shortwheel base vs Long wheelbase
Hi Mike,
Thanks for this great story. I am interested in this car. My gut feeling tells that I need shor wheelbase:
(1) Short turning radius;
(2) Better looks (personal view only!)
However I heard many comments in favor of long wheelbase:
(a) More luggage space;
(b) more comfort in driving;
(c) Seets for more passengers.
The most difficult judgment for me is about Comment (b) regarding the difference of comfort between the long and short versions. This is my major point for the choice.
Could you give some further comments and experiences regarding this point?
Thanks!
oskarf150
