LCP rope is on sale!
Master-Pull
Supporting Sponsor
For the next 10 days (Monday October 26 until November 4) Master-Pull Recovery Gear will be offering our 3/8” X 100’ LCP Winch Lines for only $244.99! The LCP or Liquid Crystal Polymer rope is a heat resistant rope that wraps around the first layer of the winch and protects the rest of the rope from the heat created by the drum. To create this rope we use 20 feet of LCP rope on the drum end spliced onto 80 feet of MP winch rope, made of quality Sk75 Dyneema fiber. This rope package is made up with a tube thimble, sling hook, and a 3ft Velcro rock guard to protect the line.
A few benefits of our synthetics are:
* Easier to handle, no leather gloves required and it floats
* Vastly safer then wire cable because it won’t snap back should it break
* Far lighter and significantly stronger then wire cable
* Rated to 18,000lbs
To order call 360 714 1313, ask for the LCP special.
-Alex
tdesanto
Could you please share with us the working load limit (WLL) or rating of the attached sling hook?
Thank you.
Tony
Master-Pull
Supporting Sponsor
Thank you.
Tony
It's a Yoke sling hook and they rate the WLL as 4500 lbs, which is just a calculation based on the Minimum Breaking Strength of 18000 (4:1 in this case). With the winchline having a MBS rating of 18,000 lbs, the hook is matched appropriately.
rugbier
Alex do you guys match competitor's prices?
And if you do, do you still honor the ExPo discount?
Thank you
shredwagon
Your site doesn't give any of the unit weights of your lines, i.e. lbs/ft. Example - with an LCP line I would need to use 3/8" dia. line allowing me 75' of winch line on a 9.5xp. With the "Superline" I could use 5/16" with 125' of line - a big improvement. But whats the weight difference between the two lines - if any? Difference between cable? Thanks.
Master-Pull
Supporting Sponsor
The hooks are the biggest weight modifiers on a synthetic line, both of those ropes would weigh considerably less then cable. I can get exact weights tomorrow at the shop, but I believe that 100 ft of 5/16ths Superline with a hook weighs around 7 lbs, cable is over 25lbs for that amount.
-Alex
tdesanto
Thank you for taking the time to provide the information.
