1995 Range Rover Classic- Expedition White! But needs TLC.
Dendy Jarrett
Expedition Portal Admin
Staff member
This should be a great truck after a good detailing. New Head Gaskets last year!!
These are the things that have been done to the 1995 in the last three years:
July 09 NEW A/C compressor- BLOWS EXTREMELY COLD!
Feb/09- New Oil Pan Gasket
Spark Plugs
Distributor Cap/rotor/Ignition Wire Set
Oct/08 Air Suspension Replacement Kit with Lift
Aug/08 New Alternator
Jan/08 New Thermostat and Gasket/System Bleed and Pressure test
Nov/07 NEW Catalytic Convertors and Muffler (big bucks!)
Feb/08 NEW Starter
Feb/08 Timing Cover Gasket/Oil Pan Gasket
Jan/07 NEW Water Pump/Drive Belt/Fan Clutch/Fan Blade
Oct/07 NEW Power Steering Pump/ Exhaust Gaskets/Used Transmission Installed
Jul/07 New Serpentine Belt/New Ignition Cowl
Sept/09 Dump Truck backed into front of truck
New Hood, Grill, Front Right Fender/All Emblems
Jul/07 New Interstate 75 month warranty Battery
Jul/06 New Fuel Lines
May/06 NEW Head Gaskets and Rebuilt Cyl. Heads/New Intake Manifold Gaskets
Feb/06 New Steering Shaft Joints and Steering Damper
Jan/06 New front Windshield
Jan/06 Replaced Left and Right Front Tie Rod Ends
Feb/05 ALL NEW Rotors/Calipers
That is the good
The bad:Transmission is hit or miss. It was replaced last year with a good used tranny, but it will be driving and then stop (not motor, but tranny). Right now it will drive like a scalded dog in Drive, but has no reverse)— This will need to be sussed out.
Head liner dropping. Rear lift gate rust. Needs a detailing. No remote, but 2 keys. Open title.
Priced for quick sale: $4600.00 IT WILL NOT HAVE THE FOLLOWING: front Hellas, Rear Lamp Guards, and swapping the wheels and tires for the a set of black Dunlop (series style) black steel wheels with NEW BFGoodrich T/A Commercial tires. AND the Transmission needs to be sussed out. BUT WILL ALSO INCLUDE A SET OF: No Longer Available Rovers North Steel Side Step/Tree Pushers and a BRAND NEW IN THE BOX Detroit 24 spline Rear Diff.
Give me a call: 615-498-6564 cell. or nashvillerover@comcast.net
As it looked with the (NO LONGER ON THE TRUCK OR WITH THE TRUCK) White Wheels:
Damage Repaired from a hit:
As it LOOKS TODAY:
A Little bit of rust on the drivers door jam:
Dendy Jarrett
Staff member
Since I have been asked:
I would sell the truck LESS the Detroit Locker that is in the box for $4100.00
And if less the Steel Side Steps: $3900.00
Thanks
Dendy
jrose609
Bump for Dendy. Nice truck.
Edit: Hey, btw, what did you do with the white Series wheels?
Dendy Jarrett
Staff member
Gee Jeff, ... you know what it is like to want to clean house a little. I'm keepin' a few toys. I guess I am getting to that age where you realize the more you have ... the less time you have!
Someone please buy this truck. It is a heck of a deal.
D
crostopher
