well my Rear sunroof has gone Liaky! Dose anyone have a good link to a how to troble shoot the leak? Also Has anyone ever just RTVed the SOB shut and stoped the leaking?
Thanks for the help
Nate
P.S. If I ever get the little stuff fixed I'll put up a Build Thread!
Probably your drain tubes are clogged up. A bunch of people have tried different ways to clean them out just search dweb whenever it comes back for some ideas. Make sure to lube up the sunroof rails when while up there also.
What Kind of silicone should I use to seal up the Rear Roof and where all should I put it or sould I just fill in the gap around the hole sunroof? This seam like the most water resistent way to do it. besides im looking to get a low SD roof rack!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
