Blazer Chalet on Ebay
77blazerchalet
Former Chalet owner
It's serial #0983, pic below, owned by one of the guys in our Yahoo chalet owners' forum. He bought a different one, so two's a crowd for him. Tough economic times have put so many of these on the market (50+ at the moment), I thought it would be too much for me to be piling these into various Expo posts, like I used to.
For folks who want to keep an eye on what's available, check into my regularly updated Google map of where they are for sale. Same old full disclosure note, I don't get a dime for doing this, just want 'em all to go to a good home instead of being junked or split apart. PM me for specific contact info.
attachment.php
Esmi
It's serial #0983, pic below, owned by one of the guys in our Yahoo chalet owners' forum. ...
attachment.php
With your encyclopedic knowledge of these rare birds, you would be a dynamite candidate to offer a brief primer on how to buy one of them. What to look for. How to evaluate. Etc.
What do you say? Are you up for it?
77blazerchalet
Former Chalet owner
Good idea before buying one is to know what you want out of one. I knew these were rare and potentially somewhat valuable as a collector vehicle, but I still wanted one mostly for actual camping. That's a slight mistake, because now I think I'd be wrecking the value of mine by altering it to suit my tastes - engine, tranny, back door, interior. 20/20 hindsight says that as good of original condition as mine is in, I would have been better off getting a non-original early '80s diesel Blazer or Jimmy that was modded to be a good cruiser with the extra weight on the back, and then I could add a modernized orphaned Chalet shell. Same spiffy-looking uncommon vehicle better suited to what I want, with no worries of messing up a rare old camper.
When buying one, consider how much or little you want to spend to fix it up the way you like. Some are around for $1000, but you may end up spending $8000 just to get it looking as good as mine, which I'll sell for $9500. Is that worth the effort for the low price? Guys who like restoration work don't mind that, others end up regretting buying the first junker they spot.
GM trucks rust big time, so determine how much repair work you can tolerate. Check the cab floor because rain might have collected into the area behind the doors and ultimately rots out the floor. Even mine as an AZ truck has rust spots in the corners of the fenders, an unavoidable condition, but not too bad to fix.
Check how long the vehicle has been sitting. Longterm storage means the rubber stuff will not be in good shape, that's the worst part about mine. Most likely, the vinyl sections of the pop up roof will be tugging loose from the roof, I've only seen two that didn't have that problem. Repair means either finding a way to heat / stretch / and re-staple the loose corner(s) back on, or a complete removal and replacement using the old bits as a pattern, if the original vinyl is hopeless.
More than likely, the LPG tank has the obsolete overflow valve. A new DOT-approved tank is less than two hundred bucks, and a new gas regulator is $40-ish. The cooktop stove is fairly bulletproof, but you are better off if the seller can prove that the fridge works. One guy said really rough bumpy driving broke up the ammonia crystals in his fridge's closed system, and it worked fine after that, after being in storage for years. That's one way of "shaking up" the fridge, I guess.
The back door latches are fragile, expect to see it broken or replaced by any variety of other latches. Chinook wasn't especially good about making fine quality doors, check to see if the whole thing is about to fall apart.
There's various other things, I suppose, much like any other '70s vintage camper. The main thing is to consider what kind of inherent problems you are willing to put up with, or that you or someone else can fix.
Esmi
77BlazerChalet: Thank you for the well-formed response.
The two take away messages I am receiving are:
1) Consider what you want: a museum piece or something to go out and use/abuse. Buy accordingly.
2) Prices vary widely ($1000 to $9500), based on condition and other factors.
BTW: Your website is great fun, and has an excellent (if brief) discussion of chalet/blazers being overloaded, and what one could/should do about that.
Thanks again.
77blazerchalet
Former Chalet owner
..BTW: Your website is great fun..
A note of clarification there, the blazerchalet.com web site is not mine but is put together by two of the original Chalet nuts named Aaron S. and Doug W., and Doug is the owner of the Yahoo forum - I am merely the Chalet diseased #2 moderator there, covering for Doug during his absences due to far-flung work projects.
Beachboyy
i appreciate the detailed response. I am going to be looking further into these in the spring and might shoot you a pm to ask a couple more in depth questions. Thanks again.
