Hitch reciever
scrubber3
Not really here
Looking for a hitch/ reciever for my gen II. I want the one that just bolts on behind the rear hook like everyone else has. Anyone know where to get one and how much? Thanks!
off-roader
4crawler.com can make one for you.
He made one for me and should still have the drawings/plans to remake one.
This is one that bolts into place using the 4 stock bolt points in the center of the bumper and has no drop to it unlike most other hitches which require you to loose alot of rear end clearance (4-6").
off-roader
Thank you sir. I've sent him an email regarding one. any idea on the price?
Sorry it was a few years back so I don't recall the price off hand. Plus mine was sort of the prototype / beta version and also metal prices have fluctuated wildly since then so I suspect his pricing will be different now.
One other thing... I had him design mine primarily as a snatch point. I'm not sure how much weight the hitch of this design can handle since it only bolts into the 4 stock bolt points which would bear the brunt of the load straight backwards versus a typical hitch which bears it on the sides where it usually is attached and not just the front center area. Questions for a design engineer to look at and answer if you plan to use it for towing.
scrubber3
Not really here
I do plan to tow a small boat. Nothing a dodge neon couldn't tow! I have the plate with the (eye-hook) setting there now which I am sure would be fine for recovery. I just need to get my brother and mines boat to some muddy places at times. I really am thankful for all of the help!
seth.c96
