Project Blue Ox
RU55ELL
Since I am trying to move further into expo build territory with my 4runner, I figured it would be worth starting a build thread for. The details of the build prior to now can be found thru the link in my signature but essentially this is what happened:
This is what I started with, '86 4Runner, 22RE, W56 tranny. Completely stock, everything worked except the rear cargo light.
Then one night, the IFS fell off of it:
And a solid front end appeared!
Right now it sits a little low in the back. I am running 63" chevy leafs and 6" shackles. I pulled two leafs out of the packs in the front to get it closer but it still needs more in the rear.
Everything added will be documented here.
RU55ELL
This is a list of what has been replaced and what is in need of replacing:
Starter - replaced 11/4/09
Oil leak - sleeved balancer shaft 1/22/10
Transmission (whines and grinds in 3rd)
Rear diff
Driver's side caliper leaking -replaced both calipers 1/16/10
Needs new cat
RU55ELL
I stopped by O'Reilly's on the way home from work and got new calipers, pads and a new cat. Magnaflow high flow for 75 bucks. I also got some tubing and fittings to extend my diff breathers. The cat will go on tonight, the calipers this weekend. I have to modify them first. Details in the link.
SilverBullet
nice work, I have a set of 2" blocks for th erear if intrested, I know not the best way, but I don't have my 87 any more and these were never installed.
RU55ELL
No thanks. I am going to move my shackle mounts back and if needed, space them out with square tubing.
RU55ELL
I actually have it up for sale right now. We'll see what happens with that before anything else happens. In other news, I replaced the leaking caliper today. :)
RU55ELL
LOL, just a bit of everything. Every time I have to fold up to get in it, it makes me want to sell it. I want something newer but I sure don't want the payment. I have it on TTORA to see what kind of interest it gets.
RU55ELL
I got out in the garage last night and removed the balancer and found that it had a worn groove in it at the oil seal and oil was ever-so-slowly leaking out around the balancer shaft. Fel-Pro makes a repair kit for it that includes a metal sleeve that goes around the balancer shaft and red locking compound to keep it on tight.
What happens is, dirt/grit gets stuck in the front oil seal and grinds against the balancer shaft. After a long time (24 years for mine) it wears a groove into the seal. You won't really notice a leak until you put a new seal in like I did when I replaced the head gasket and pretty much the whole front of the engine. Now it has a seal with no dirt and a leak path is formed. The sleeve locks around the shaft so there is no more groove to leak past. No more leaky for me. :D
I also forgot to mention that I replaced both front brake calipers last weekend. Very easy job, 30 minutes per side.
RU55ELL
Looks like I have a for sure buyer coming from Dallas on Sunday. Looks like I'll be starting a new thread next week.
Goldenbora
