Need a picture of a 05-09 Taco ABS wire
xcmountain80
Yes yes while a random request, I'm trying to sort out some issues on my dads 06 Double cab. A body lift was installed and the ABS wire pulled apart (driver side heading down to the hub with connector located across from the oil filter toward the firewall), the upper portion with connector is there but the lower 2 wires pulled out of the connector. Sounds simple just plug them back in and if in the wrong configuration switch them right? Well that scientific approach did not work. I need a picture of which color goes where. Thank you so much! I had posted this on TTORA but they are to busy doing other things then fulfill such a basic request.
Aaron
nvprospector
Hope this is the one
I am assuming that this is the connector that you are talking about. It is located across from the oil filter near the power distribution box. It is a gray connector that has only two wires running through it.
Note: Just so you know, this is a connector for a truck that does not have VSC or Trac. I don’t know if the connectors are different for the trucks that have those options.
Skim
Replace the damaged harness or sensor. You dont want to take a chance with ABS/VSC/TRAC operation. It is a sensitive system.
xcmountain80
I will just re-splice the wire (lengthen) and call it a day. It's been like this for a while. There is no abs as it stands but will be when I fix it. I realize most folks didn't grow up without ABS but my first 4 cars had no ABS system, you just have to know how to drive. Thank You for all the help Expo. Oh and on a side not there is no trac or vsc on this Tacoma just ABS.
Aaron
crostopher
