install belts on 22re 94 toyota p/u
colotaco
Hey all,
I went thru the FSM's and couldn't find the page(s) where it detailed how to install belts on a 22re in a 94 p/u? How many? No a/c or p/s for sure, anybody have a good picture from a manual with a how to?
DaveInDenver
Middle Income Semi-Redneck
Hey all,
Factory Service Manual: http://www.ncttora.com/fsm/1993/index.html
The description is under charging system, how to remove the generator (alternator).
Without AC or PS, you should have just the one belt. On the 22R-E the belts are from back (nearest to engine) to front (nearest radiator): (1) water pump & alternator, (2) AC and (3) PS.
Loosen the alternator top and bottom bolts (the top is slotted on the bracket) and rotate the alternator in towards the engine. That will take the pressure off the belt. Then work it up and out over the fan. Reverse with new belt, using the alternator to tension the belt.
colotaco
So the belt should go around the inner most center pulley and the alternator?
dhuss
