adrenaline503
I had just gotten my swayaway torsion bars all set up and adjusted. On the way home I heard a bang and the whole drivers side suspension dropped to the bump stops. Turns out the mount on the lower arm stripped out. I have heard of this happening before but I can't remember where. Is there a consensus on why this occurs? My first two thoughts are either the torsion bar wasn't seated correctly which I doubt since the rear torsion bar adjustment bolt as well seated which "should" ensure everything is correct. My second guess is too much tension on the torsion bar, which I also doubt. I was using a regular length socket wrench to do the adjustments so I doubt I could have put enough tension on it to strip it. The adjustment bolt wasn't bottomed out although I had just reindexed. Oddly, the ride after reindexing was much more supple than before. Perhaps that additional softness was my bracket slowly stripping itself. FML.
So now what? Should I use the swayaways again or might there be an inherent problem? They were used but in good condition.
it looks like a new bracket is about $51.00 bucks and I MIGHT be able to find one in a junk yard. Not many Frontiers with good fronts out here. Are the longer arms "lift versions" more robust or do they use the same stock torsion bar mount?
