GX Storage/Bed project
TexGX
I finally started my cargo system for the GX. Here are my ideas:
1. Light as possible. No drawer, I like the idea of bins.
2. Sleeping platform for one.
3. Fridge storage with place for battery or water can.
4. Can be removed fairly easily.
This is where I am with the project. Suggestions are welcome. Here are a few of the things I need to work out:
1. What to cover it with (carpet or bedliner)? Bedliner is winning so far.
2. How to mount it to the truck? Thinking L brackets to the tiedowns.
3. I will add a slide for the fridge later, but until then, how to hold it down?
4. How to hold the loose part for the bed to the unit? Dowel rods?
TexGX
Token
Bedliner.. I did carpet on the box in the back of the H3.. Didn't occur to me at the time how crappy it's gonna look the first time I toss a muddy snatch strap or a few sticks of firewood back there..
May try and find a big sheet of rubber to toss over it catch the bulk of the crap.
Desert Dan
That looks pretty good and easliy removable.
You can pick of a chase loung pad (3-4" foam) that would work good as a bed.
TexGX
Token,
I am going to go with the bedliner. I bought 3 cans today.
Desert Dan,
That is a great idea.:wings: I was thinking of buying the caballas bed pad, but will have to check prices now.
I added a side wing on the sleeping side to give me just a little more room to sleep. It ends up close to 30 inches. I drilled a bunch of holes around the rear of the fridge for extra ventilation. Also added some in the rear box incase I put a battery in there.
Can I have a battery inside the truck with me? Anything I should be concerned with?
TexGX
TexGX
The bedliner is not working out. I guess the stuff I used was not the best. Now I need to decide if I want to try and strip it off, carpet it or start over. All I would need to buy would be a single peice of oak ply. I may try sanding it and if it does not work well, then I will start over. If so I will put this one up for sale.
Any suggestions?
TexGX
corax
how about just covering it with rubber, like EPDM roofing material. Glue it on on forget about it + easy to clean
rusty_tlc
I used a cheap commercial grade area carpet I got at Home depot to cover the platform in the back of my FJ40. I think a 6X8 piece cost around $12. It's holding up pretty well but it's so cheap i could replace it a couple of times a year. I clean it with a garden hose.
BTW I don't have a hard top and almost never put the soft top on so it see's a lot of dust dirt and weather.
TexGX
Here is the finished product:
I think everything turned out really well. I am excited to give it a test run.
Desert Dan,
The chase pad works great!
TexGX
TexGX
djrez4,
The back platform rest on a lip on the main frame and the back rest on the second row seat folded down but not flipped up.
TexGX
PGW
What are you using for a hinge for the sleeping platform? I'm working on nearly the exact same thing on my Grand Cherokee, except the 'cubby' is full width because I don't have a fridge.
TexGX
PGW,
The only hinge I used was for the wing on the drivers side. The sleeping platform velcros to the top piece when traveling and rest on a lip in the back and the second row seat when deploded as a bed.
I did try the set up last night and it worked Great!! I like that I can get into the passanger back seat and take my shoes off, then crawl into bed. Having the DVD player did not suck either. I am very happy with the setup.
TexGX
stolenheron
what did you use since the final coating? did you redo the bedliner or is that just paint or what?
i currently have a carpetted/canvas setup in the back of my rover, it looks fantastic, but i need to edit my original design a bit, which means i'm gonna need to resurface it, i'd like to redo it and need ideas for resurfacing. i used MDF board, vs plywood, which was a mistake, but it still works fine. its just heavy and a bit more sensitive to water. so i need to coat it and coat it well.
TexGX
I just painted over the bedliner. I would buy the roll on kind next time. I do like the fact I can just touch up the paint. It seems to be working fine.
TexGX
DanoWall
