Four Wheel Pop Up K5 Question.
truck mechanic
Dont know for sure, but I would think the that it would not be a bolt on because the 72 has a full removable roof and the 79 has a cab over the driver and passanger.
just my .02
Paul
mlaux
On the older full top blazers they just cut the fiberglass roof to match the newer body style. I have installed a Hallmark from a newer blazer onto a 73-75 full roof K5 with no real problems. That being said I would still take some measurements because you never know.
Stan@FourWheel
You would probably need to take some careful measurements.
It might / might not fit.
The older FWC's that were build for the Blazer, Bronco, & Scott vehicles were all a bit different sized.
Each one was somewhat customized to fit the particular truck it was going on.
Especially the camper to cab fit / camper to cab boot & seal.
A long shot...but any idea if a FW from a 72 Jimmy might fit on a 79 K5?
DW
Herbie
Rendezvous Conspirator
Thanks for the info Stan! Is FWC basically out of the business of doing Blazer/Bronco campers and sticking to your standard lineup now, or would a customer still be able to go down this road if they so choose?
1976K5Chalet
Well...i found a camper for myself finally...in colorado of course...and close by which was a plus as well.
I have it mounted but the cab to camper seal is a big issue. Right side is not tucking up...so i guess i will have to finger something out to solve it..ie: new front board that utilizes the oem tops front bolt holes to draw it forward...
Any ideas stan?
DW
