Canadian Moose
Day 19
Day 19 - Interior Project - Stage 1
The warmer weather is motivation for to work on the Jeep.
Here are some photos from before: The previous owner left it in disgusting shape.
I started off by pulling all the carpet out of the 2000 limited. This carpet was way cleaner and was also higher quality. I proceeded to clean it so that it was like new.
Then I pulled out the seats, carpet and grey center console from my Jeep.
The rust situation wasn't that bad at all. I sanded it down a bit and hit it with some black rust paint.
I started replacing the carpet and grey trim pieces with the black stuff from the newer xj. I replaced the center console with the black one. I installed the heated seat controls as well as the part brake lever from the 2000 as mine was broken.
Side note on the heated power leather seats. All the wiring and controls are self contained. There are 3 wires then run to the jeep, a ground wire, ignition power and the main power. The main power simply plugged into the interior fuse box.
