Dry firing a CZ 452
Hoosier 45
Hi All,
I am starting to train my daughter how to shoot and was wanting to use my 452 with iron sights.
When I was growing up, back in the old days, we were alway told not to dry fire a rifle/shot gun. Have things changed? have better metalurgy and mfg. made this an old dads tail?
Do they even make snap caps for a .22??
Thanks
SunTzuNephew
You should not dry-fire a rimfire. Most centerfires are OK (a very few have unsupported firing pins that will peen their stops).
I don't recall ever seeing .22LR snap caps and a quick look at Brownells didn't turn them up, but if you don't have any empty cases, you can always just pull the bullets on a few rounds of ammo and dump the powder, and use the empty cases to support the firing pin. The primer going off the first time isn't significant at all - and you can just dump the powder in the sink, or demonstrate to your daughter that it just burns (unless the pressure is contained).
Have fun!
Hoosier 45
Thanks, My plan was to have her spend a while dry firing to work on sight picture and trigger squeeze.
I remember spending days doing the same at Pendleton and how effective it was for most.
howell_jd
Pachmayr makes snapcaps for virtually every caliber - including .22LR. You may find them conveniently on Amazon.com or elsewhere. I do not encourage using emptied ammo as it is possible to mix blank and live by confusion...snapcaps are readily identifiable and less easily mixed with live ammunition. I can relate dozens of stories of stripping magazines because of a report of blank and live ammunition mixed up during a training event following a qualification range. Obviously a live round through a blank adapter would ruin a day very quickly - same thing with an accidentally "live" .22LR during "dry" fire sight picture and trigger squeeze drills!
SunTzuNephew
Well, a dead .22LR case looks quite a bit different than a live one, won't (usually) feed from any magazine (including tubular or box) and so would have to be carefully hand-loaded into the chamber.
Quite a bit different than military crimped 'blank' ammo that has the outward appearance (for certain values of appearance) of loaded ammo, and will load from a magazine.
I always make certain that before I do any dry-fire practice I put all live ammo (loaded mags, cartridges, etc) away - in a closed container. No point in being risky.
But, thanks for the tip about the .22LR snap caps. I'll look for some.
Henrybrowne
