'04 DC Suspension Advice
Box Rocket
Has anyone found a suitable option for longer shackles to work with the rear dakar springs?
I'm on the search and could use some help.
Here's the best options I've found so far..... the Toytec 1" lift shackles should work and allow me to reuse the greasable OME shackle pins. Could require redrilling the shackle plates to correct size.
The Daystar 1.25" lift shackles might work too if you needed a little more height but since they have a center support I'm uncertain if they are the correct width for the OME bushings.
Tacoma Extended Shackles
Henrybrowne
