FE649 Headlight
DzlToy
Looking for width and height of glass area of an FE649 headlight, which I believe has two rectangular lights on each side that are the same size.
Also would be great if anyone had a cross reference part number for something like Osram/Sylvania or other majour manufacturer.
Thanks
Jon
PKDreamers
Hi are the lights 165mmx100mm if so Hella part numbers are 1041 High , 1042 High/low they take H1 anh H4 bulbs or Navra brand part number 72066 high/low, 72076 High
again take H1 and H4 bulbs in either 12v or 24v
I hope that helps if not il find you sum more numbers we i get to work on monday.
Pete
bptp7270
On the subject of headlights. Does anyone know where to get reasonably priced replacement units for my FG649, as mine have both got cracked lenses and as a result the reflectors have faded?
PKDreamers
Try Moore truck parts.
or ALL CRASH PARTS MELB 03-95487109
PKDreamers
[If anyone has exact measurements from a domestic model that would be much appreciated.
Thanks
jon[/QUOTE]
Should be 165mm x100mm Look at hella or Wagner which is a Federal-Mogul campany.
zhukoveli
