Replacing leas acid with AGM Battery
Romer
I am replacing the lead acid battery with a group 31 Deka AGM. The Kimberley has a Centuray battery charger installed
I can charger these at 2amp/12V or 6amp/12V via a switch
The manual has a feedback loop
It says it will charge a battery w/o cell caps _Charger is from 2001
It says for lead-acid batteries only not be used on low voltage batteries. Not sure if thats because AGMs were not that popular when my trailer was built
Do I need to replace the battery charger?
R_Lefebvre
I would suggest you get a new one meant for AGM's. I don't know all the details, but there are differences in charging requirements. My electronic charger has settings for Wet Cell, Gel Cell, and AGM. Then you have Odyssey's, which have different requirements altogether.
Romer
Thanks -Thats what I thought
Need to see if there is anything unique about my wiring setup before I get a new one
Hants
I have a Xantrex TruCharge 10 in mine that is coming out (being replaced with a Xantrex TruCharge 40 to support the 300AH bank I'm installing :elkgrin:).
The TruCharge batteries are smart 3 stage chargers, and they know how to properly charge AGM's.
You're welcome to the 10, if you're interested. Won't be available until late July or early August, though.
