Goal0 solar systems
silvercruiser
Hi,
I did a search and couldn't find anything on Goal0 systems. Does anyone have any experience or thoughts about the brand, company, products, service?
I'm considering the Scout Explorer Kit. Looks durable and could more than power camping accessories.
http://www.goal0.com/
thanks in advance,
David...
claki
Scout
Yeah - I haven't used it but my friend who is a boy scout master used it at a campout this past winter. Surprised it did so well left out in the snow. I recently purchased the Sherpa 50 kit. It's worked well for my rock climbing sessions. Hope this helps.
18seeds
Anybody know how well the below set up will do with Edgestar 43-quart ( http://www.expeditionportal.com/forum/showthread.php?t=45419)
* Description
Take power to earth's most extreme places.
When your mission is to maintain power for longer periods of time in the world's most extreme conditions, the Ranger 350 rechargeable power pack delivers exactly what you need to succeed. Capable of powering a facility up to 1,200 square feet, it's designed for base camps and long-stay environments. Charge via wall, solar panels or car adapter and use as a primary source of power for lighting, cooling and accessories. Stack up to three additional EXTREME batteries and get a total of 1,600 watt-hours of power. Mission accomplished.
Key Benefits of Ranger 350 Battery
* 350 watt hours of Power Pack storage capacity
* LCD status monitor keeps track of power storage in 20% increments
* Ergonomic rubberized handle for greater comfort and grip
* UV treated and weather-resistant
* Backup and replaceable fuses to protect from power surges
* Built-in temperature control and fuse systems to ensure safety and long-term performance
Key Benefits of Extreme 30M Solar Panel
* 30 watt highly efficient mono-crystalline solar panel
* Can be linked to other panels for maximum energy
Key Benefits of Ranger UI (Universal Inverter)
* Universal Inverter which provides up to 400 watts of continuous power and 800 watts peak
What's in the Box
1 x Ranger 350 battery
2 x Extreme 30M solar panels
1 x Ranger UI (Universal Inverter)
1 x AC wall charger
18seeds
Or this Kit the Sherpa 50
Go light with the Sherpa 50 power system
For the minimalist that requires power to keep essential devices charged this power kit provides 50 watt hours of renewable power in a tight fitting kit. Charge the Sherpa 50 battery with the Nomad 13.5M solar array. And stay lit up with our efficient LED Estrella light.
Key Benefits of the Sherpa 50 Battery
* 50-watt hours of Power Pack storage capacity
* Chain up to three (3) additional Sherpa power packs
* Powers a variety of USB ,DC, and AC* devices
* Compatible with Sherpa UI - Universal Inverter for 100 watt AC output
* Powered by GOALØ LiFe batteries that are rated for 2,000 -3,000 cycles
* Equivalent to 30,000 AA alkaline batteries
* Rugged and weather resistant to protect against the elements
* Integrated charge controller protects internal battery and connected devices from burnout and electrical spikes
* Replaceable fuses
* Tested and certified by FCC and CE
*AC output is not included (See Sherpa UI (Universal Inverter))
Key Benefits of the Nomad 13.5M Solar Array
* 13.5 watt mono-crystalline solar array
* Foldable nylon construction is lightweight and portable
* Water-resistant to protect from the elements
* Built-in pocket to store charging cord
* Four (4) sturdy grommets provide various hanging options
* Tested and certified by CE
What's in the Box:
1 x Sherpa 50 battery
1 x Nomad 13.5M solar array
1 x AC Wall Charger
1 x 12V output female cigarette adapter
wrcsixeight
I guess if you are going to be driving to camp, setting up camp, and then needing the camp to be electrically self sufficient while you are out wheeling, then these systems would work nicely.
If you are not planning on leaving camp with the vehicle, I would go the route of individual 60 watt + Panel, charge controller, battery and inverter.
I think If I needed a vehicleless electrically self sufficient camp, I would still do individual components matched to my demands, rather than a kit.
claki
Sherpa 50
No clue on the bigger system. I bought the sherpa 50 kit. It works surprisingly well. I used to own a brunton system. Never worked. For me, this kit has worked great. I've gone on three backpacking trips, one into the sierras, for three to five days. Charged up off of the panel in about eight hours. Kept my phone, camera and gps charged with no problem. It's really light and packs nicely in the pack. When packing I draped the panel over my backpack to keep the sherpa battery charged. The bigger kit, for what i do, is too big for what i do.
18seeds
i couldn't pass up a good deal so i put together my own kit
i won't be able to test it out for a few weeks :(
silvercruiser
Thanks for the feedback. Need to put a lot more thought into this before I take the plunge. 18seeds keep us posted.
David...
I just put together and ordered a kit today. I thought about going the DIY route but decided that given how I travel and considering that I may install this in multiple set ups (various trailers, an Airstream, and my pickup) that a system that can be linked together (or, alternatively, read: proprietary), is the right direction for me. Once it arrives, I'll test and take pictures.
-Josh
JIMBO
:sombrero: The 60watt pnl and 7-amp controller has worked for me for about three years !
Keeps the Engle 40qt/lights and occasional inverter use, functioning and one battery topped off
:costumed-smiley-007:wings: JIMBO
My kit arrived today. Great packaging and everything looks good. I hope to be able to test this in the next few weeks, but the lights are BRIGHT which is a good start. I like the idea of not having to consider a generator.
My kit:
1 Boulder 30M Panel - for dry camping in trailer on when in truck
1 Ranger 350 Battery - for vehicle-based adventures
1 Ranger UI
3 Light-A-Life 3W lights (can be daisy-chained...very cool)
1 Sherpa 13.5 folding Solar Panel
1 Sherpa 50 Battery - for "lighter" weight camping
1 Sherpa UI
Some pictures:
Whole Kits except my Boulder 30M Panel (which is in my truck)
zhukoveli
