Jacks
gasman
i made mine they were intigrated into the tailgate frame, but you can buy the nice crank up ones at harbour freight/ princess auto/ any trailer supply place.
SilverBullet
FWIW, I have an extra BAL leveler from my Tent Trailer if anyone wants to try to modify one of those or make a mount to make it work.
i'm doing something very similar with pre-drilled tube. it only about $10
worth of material but then it not as slick looking, the curse of being cheap...
Titanpat57
Ain't a damn thing the matter with THAT. !!
Cheap and functional can be our friend...
Here is what I did on the current build..somewhere along what Elmo did, a drop foot jack that slides into the bumper ends
rdsk8ter
do you still have any wobble front to rear side to side with ths setup?
gasman
wobble ? not sure what you mean , the trailer is steady as a rock, i carry a small pipe wrench and use it to turn the feet in or out as needed to level out the trailer,, i can lift the wheels off the ground this way.. absolutley rock steady,, . the crank up jacks would prolly be a little bit easier, but my system works for me just fine, and there not gonna break and leave me scrambling for a trail fix somewhere,
compactcamping
I use Atwood friction jacks, available at most RV parts stores. They come in two extended lengths, 16.5" and 23.5". I mount them in receiver tubes so they are removable to keep them from being damaged.
Hill Bill E.
Oath Keeper
I use Atwood friction jacks, available at most RV parts stores. ..... I mount them in receiver tubes so they are removable to keep them from being damaged.
Good idea! You could make a shackle/recovery point that fit's the reciever when on the trail, swap out to the stabilizer jack for camping.:ylsmoke:
oskarf150
