My M416 Trailer Build has started.
KE5QVT
added more to my m416
I had a local fab shop weld up a frame for my future RTT. I also modified the tongue by removing the stock military lunette and replaced it with a 48" tongue. I kept the lunette type hitch for greater flex off road. I have a 30 gallon water tank mounted with a demand water pump. You can see the fill nozzle and water spic on the front left side. My propane bottles are 10 gallon transparent bottles so I can see the fluid and KNOW when they are getting low. I also have two 5 gallon fuel cells up front, and two ammo cans in the rear. One is for a deep cycle battery and inverter, the other is for tools or what ever. I also added two cans up front for what ever as well. All cans, fuels, propanes etc can all be pad locked.
I also added another receiver below the spare tire to add a bike rack when ever needed.
The next project is to add hinged bars on the sides of the frame to allow a kayak or canoe to be held.
Jekyll2000
Interested in selling the lunette casting and lunette. I'm looking for one for my M416. Thanks,
Tony
alexrex20
hmmmmmmmmmmmmm
KE5QVT
Dude!!!
Where did you come up with the photos of my truck? WOW, my trailer has come a LONG way since then!!!!
gasman
wow . nice job, i really like the way you have extended the tounge. were you able to retain the ability to rotate the ring or is it welded solid?, i have been thinking of different ways to extend my m101 , but man i really like your version, did i say i really really like it ?
KE5QVT
Did you go over to iH8mud to see the entire build? the tongue extenstion does wonders for trailering and backing. plus gives more storage area. I keep the lunette's ability to rotate 360 degrees just made it a real tight twist so it only does it when really needed.
I have much much more since this last post. Please go take a l00k and let me know you r thughts:smiley_drive:
alexrex20
i met you (and T4x4T) at BVORR way back in November 09. your nickname is Goose? or something like that...? :D
you had just picked up the trailer a few weeks before that BVORR trip. and yes, it sure has come a long way!
womacje
How far is your tub from the end of your coupler/eye of the "ball mount". I'd love to get your opinion of tongue length.
Jeremy
old_blue
I have one of these trailers, and would like to swap the axle so I can use my 6 x 5.5 spare. Do you happen to know the specs of the axle you ordered? Thanks!
womacje
I matched the existing axles specs, hub face to hub face and spring perch center to spring perch center. Hope that helps.
Jeremy
