Ford 12gallon water tank that sportmobile uses?
shawn_nj
Anyone have a link to purchase the under van / side mounted 12 gallon water tank that sportsmoblie uses on there ford vans? Its smaller then I want, but my 30 gallon is taking up too much valuable realestate.
Thanks!
Topher Walters
Sportsmobile uses a few (2-3) different water tanks but I am pretty sure none are 30 gallons (at most 10-20 gallon) and all of the ones I have seen are interior mounted not exterior.
1leglance
look around the marine shops for anything in any size or shape
West Marine and other places have great deals.
Honestly I am suprised we don't have more crossover between the marine world and the overlanding one.
shawn_nj
My 30gal will fit where the spare tire is, but I have not found another spot I liked for the spare tire. Back door does not work as it obstructs the door from opening enough to be bothersome... and I load dirt bikes, mtn bikes, and jetskis in my van, and need max door opening clearance. Thought about putting the spare on the roof, but that requires a rack to be intalled, and adds more wind resistance which the van does not need. So as of right now I just put the 30gallon on the floor between back seat and drivers seat. It has on/off and quick connects, so if 2 people needs to sit in the back seat I can remove it in under 5mins. But I want to get the tank out of the van and mounted under. Just takes up too much space.
I did some measuring and I can get a 18-20 gallon custom made tank to fit under my back seat. Which is my next best option, but I like the storage I have under the seat now. If anyone has installed tanks under there vans any and all ideas are GREATLY appreciated! I thought I read sportsmobile had a undervan side mounted grey water tank, but I could be mistaken. 10-20 gallons is low for my needs, 20-30 is good, 30-40 is ideal.
shawn_nj
Where does your 30gal sit and what are you doing with it once removed?
I had it custom made and it will fit in spare tire location. Going to hang on to it just incase I go on a multi day trip where I need alot of water.
Bummer I was really hoping they were external!
Thanks for the tip. I was checking out west marines tanks last time I was @ the west super store that just opened near me. And I am with you on the marine/overland thinking. Marine grade products are normally built 1000x better then "RV" class products.
bstory
Defender Marine for good pricing
We got a polyethylene water tank through Defender - seemed like much the best price and the tanks come in a huge number of stock sizes.
RocKrawler
Supporting Sponsor
There are interior soft tanks (Flexi Tanks) available as well, we just got one for a customer with an FJ80 Land Cruiser that installs in the rear 1/4 panel and aside from the hose coming out of the bottom corner of the interior panel its invisible and utilizes no useable interior space.
Photog
You could try the other Class-B RV builders, to see about external tanks. You will have to be careful during freezing conditions.
Roadtrek
Pleasure Way
Leisure
Chinook
Winnebago
Etc........
gp01
