TexasTJ
Climbing Nerd
Back in Late June my Rover started to leak coolant from the water pump. I ordered all the parts to fix it but before I could the rover started to over heat waiting to pick up a friend. Never got to the red and I turned it off quick. As soon as I started moving again the temp went back down. The next day the parts came in and I set to work fixing my leak. I replaced the water pump and seal, at the same time I put in all new hoses and a new thermostat. All done. I only driver the Rover on the weekend and I really don’t use the AC much even in Texas I just like the windows down. Last night while driving my Girlfriend to dinner with the Ac on, I looked down to check the temp and it was up a little from normal. Not much but enough to catch my eye. With the AC off the marker sits just touching the bottom of the water graphic under the center of the ark. While in the parking lot with the AC set to power level 3 it was setting a little above center make of the ark. Is this normal since I don’t run the AC much I’m just not sure. Also what’s the normal engine temp suppose to be?
Thanks
Nate
:beer:
Thanks
Nate
:beer:
