Diesel Ramcharger
huntsonora
Just saw a custom built Ramcharger for sale and it is SWEET! It has a 12 valve from a 97 3500 and an automatic transmission. I'll see if I can post a pic but would LOVE to hear your opinions on this truck
huntsonora
Spur
Looks awesome!
I'm curious what they did to the suspension to support the weight of the cummins. From experience I know that a lot needs to be done to make it function well.
shortbus4x4
Judging from the engine compartment pictures it looks like they did a pretty good job on the swap. The wiring is all nice and tidy, I have seen some where it looks like a rats nest of wiring. Generally if they took the time to tidy up the wiring they did the rest of the swap with equal care.
Desert Dan
Nice!!
All the goodies from a doner diesel pick-up!
I wish Doge and Ford would make a fullsize SUV based on the Power Wagon and the Raptor.
chasespeed
I have seen a few of those... and its a pretty straight-forward swap....
And, it has 8 lugs... so.... probably got the springs out of a 3/4 or 1 ton cummins(first gen, they bolt right right in), and the axles as well....
All it takes is the motor mounts from a 1st gen cummins, and the cummins of yoru choice....
The 12v is especially easy, as, it really only NEEDS a 1 wire....
But, its a good looking truck, I'd snag it in a heartbeat, IF it would pass here...
Chase
redthies
Renaissance Redneck
I know I said "don't ever sell your 12 valve truck" back when you were contemplating the F350, but, in this case I will make an exception! That thing is freakin gorgeous! I would buy it in a second... (And then go give the wheels to someone at the mall, and buy real wheels for it!).
huntsonora
Here is the ad...
Up for sale is a 93 Ramcharger I've owned for about 4 years, with a Cummins/drivetrain conversion I did almost 2 years ago. Truck has 143,000 miles, the engine has 158,000 miles.
Engine: 97 180HP 12V from 3500 Auto truck(currently 360HP/860TQ)
Trans: DTT 47RH with some 48RE internals
Axles: D60/70 3.54 from 91 W250 donor truck
Xfercase: 205 from same donor truck above
Suspension: Alcan 3inch springs, Rancho 9000XL shocks
All wiring is complete and accurate for a 93 diesel application. Everything works, A/C, Cruise, gauges, Diesel infocenter, ABS. Some other notable items, include Borgeson steering shaft, LS Dana70, Intercooled core support with IC setup from donor, engine has HTT 62/65/12, DDP2s, 100plate, 3K GSK, 16.5 timing. Dealer option diesel tach, Autometer ZSeries Pyro,Boost,Trans gauges on the pillar.
Patman
I was under the impression that porn was not allowed on ExPo!!
:drool:
Having wheeled much of the west in a Ramcharger, I would throw my FJ60 to the curb in a sec for this if the funds were there. Space is not a concern with a Charger!
